Question about Breville SHM2 Stand Mixer
Where can I get replacement Beater Blades for my Breville SHM2 mixer?
  • 43 Answers
Call Breville or look on their website at http://www.breville.com/. If you are in the US, call 1-866-273-8455 for replacement parts.
Posted on May 26, 2011
I have dry hardened dough stuck in the motor area, i need to open it up and remove the flour which is ratteling
hi. 1. remove the screw near the cable. 2. use something sharp, small and robust to lever out the white screw cover which is underneath and in the middle. it looks like plastic moulding. 3. the screw head has a raised middle in the flat head groove. I put a medium flat head screwdriver in a vice and used a hack saw to remove some metal in the middle. it only took 15 minutes so don't be put off. unscrew. 4. lift off the cover. 5.use a toothbrush and the something pokey to clean.
Feb 04, 2013 | Breville SHM2 Twin Hand and Stand Mixer
I was bought it for christmas last year forgot to check it and now find it does not have a manual please can you help
Hi Valerie:
The Instruction Booklet for the Breville SHM2 380 Watts Stand Mixer can be downloaded from the following address:
http://ecx.images-amazon.com/images/I/A1Qx-DxXTMS.pdf
Thank you for using FixYa!
Oct 16, 2011 | Breville SHM2 Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Please can u tell me if i can get the blades for this mixer and how much they will cost.
Yes the blades are available as spare parts for the Mixer. I suggest that you contact any nearby dealer of the Mixer.The price depends on the Quality and there are many makes of blades which is compatible with your mixer.
Mar 27, 2011 | Breville SHM2 Stand Mixer
Mixer catching bottom of bowl model hobart a120
There are several possible causes:1. The blades of the beater/s may be distorted (bent) 2. The beaters are in the wrong way round 3. The bottom tray is not seated down properly - there may be something in the central hole 4. The bowl may be damaged
Sep 22, 2009 | Hobart A200 Stand Mixer
Beater too low-will not lock
I would check the bottom of the beater blades to see if they are out of shape.,or is the base of the mixer raised somehow to cause this problem
Jul 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Broken beater on the Bravetti ep586 HB
Look on unit and find maker and call and they will tell you where to find.
Mar 13, 2009 | Food Mixers
The mixing blades in my KitchenAid mixer sit too low, which makes the head bump around a lot. How do I fix this? I've tightened all the screws I can see.
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Dec 07, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Breville SHM2 Stand Mixer Logo
1,266 people viewed this question
Top Breville Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
