Question about Konica Minolta DiALTA Di200 Copier
My DiAlta Di200 copier is asking for access code after it was unpluged and refused to work or accept any command.
sir fixalot
  • 146 Answers
SOURCE: minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Posted on Nov 11, 2008
chibibarako
  • 7 Answers
SOURCE: What year was the Dialta
It looks like it was developed in 2002, just before Konica and Minolta merged. Here's a link to the product information guide, and another to the user's manual.
Posted on Dec 16, 2008
  • 17 Answers
SOURCE: 4 digit acces code
First, enter the tech rep mode:
moz-screenshot.jpgPress the Utility key, then the meter count button on the touchpad.
Enter "Stop - 0 - 0 - Stop - 0 - 1" on the keypad. You will enter the tech rep mode.
Select "Administrator # Input." Note this number, or change it to something you can remember.
Now, go back to the Utility screen and select "Admin. Management." Enter the code you just learned, select "Copy Track Mode," and change it to "Off." Exit the mode and you're good to go.
Alternatively, you can select "Copy Track Data," and note the access codes (or enter new ones).
jqsababa967
  • 145 Answers
SOURCE: Malfunction code C0045 Minoltal/Dialta 350F means what
replace the ozone fan motor...if it keeps happenin
Posted on Mar 01, 2009
jqsababa967
  • 145 Answers
SOURCE: Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Posted on Feb 11, 2010
Error cod sc32-04
There is no SC3204 or C3204 code on the Minolta Di200. I would either need the correct code or the correct model of Minolta you have. Please provide better information so I may assist you further.
Thank You for using Fixya.
Oct 28, 2011 | Konica Minolta DiALTA Di200 Copier
Ill already replace imaging unit. How can it ask for a code?
when you replaced the image unit did you reset the counter for the drum
Feb 14, 2011 | Konica Minolta DiALTA Di200 Copier
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
About the codes
Sure which one do you want to know about. There are about a 100 or so codes...
Jun 28, 2009 | Konica Minolta DiALTA Di200 Copier
4 digit acces code
Nov 26, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Copier
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!
May 10, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
