Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
Does model# msd2652keu have a drain pan or not. can't find one. serial# 50909406ll
    Genius:
  • 1,622 Answers
Hi, There is a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
The solution needs to be injected into that plugged hole. When the water from the injector starts going down (into the drip pan at the back) instead of coming back up, the blockage is removed and the problem should be solved.forgot to clarify that the solution needs to be injected into that plugged hole. When the water from the injector starts going down (into the drip pan at the back) instead of coming back up, the blockage is removed and the problem should be solved.
Take care.
Posted on May 26, 2011
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore portable air conditioner Model 484.35338 serial no AP0000320252 made in spain code X5RKMFE709/01 quit running after 4hrs run. DRAIN WATER light is on. How is the water drained?
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan that can hold a least a quart of water. Or roll it to an area, where you can allow it to just drain. If you drain it in place into a pan, be sure to turn the unit OFF & unplug it, before draining the water.
If you have misplaced your Owner's Manual, you can get one online from Sears Parts Direct.
Hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Kenmore Heating & Cooling
I have a Kenmore Coldspot/ model # 106. 77992791 and serial no. EH 2911561. When the freezer defrost the water does not drain into the pan but drains into the refirgerator. How do i correct the...
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 20, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Where is the transmission drain plug
I'm not really sure on this late of a model. The drain is on the bottom of the transmission and I think it's a pipe plug on the front of the transmission oil pan. The earlier models that I work on had a drain plug that looked exactly like the engine oil drain plug that was also on the bottom of the oil pan. Many a transmission has been drained thinking it was the engine oil drain. Go to this site and look at the picture of the transmission housing. http://www.bikebandit.com/2008-harley-davidson-touring-street-glide-flhx/o/m18635#sch624765 Pay particular attention to the oil pan gasket at the front of the pan. Notice the hole in the gasket directly above the socket head pipe plug, part #96. This looks like the transmission drain to me.
Good Luck
Steve
May 29, 2011 | 2008 Harley Davidson FLHX Street Glide
CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
Oct 07, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Fridge has an odor
steve125
You can remove the acess panel from the back,the grill from the front, even pull out the drip pan from underneath.(small socket or nutdriver is all you need) Flood the area with light, (Unplug the unit first) and I bet you will find the culprit up under there somewhere.
good luck
handiman518
Jan 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
103 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
