Question about Samsung Televison & Video
Tv's volume automatically gone to 100 its not comimg down and we haven't got samsung originalremote
  • 10,594 Answers
Please check +Vol button on TV, it seems stuck / pressed by itself.
Posted on Aug 16, 2008
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Samsung le40b530
Chances are that one of the volume buttons (either on the TV itself or on the remote) is stuck. You'll be able to know if it's the remote by taking out its batteries and trying the same process. If the issue persists, see if the volume down button on the TV is stuck and can be freed.
Dec 18, 2013 | RCA Audio Players & Recorders
Bush tv volume sticking on 100
This could be a problem with either the remote or the television. Try moving the remote out of the signal area for the tv (or take out the batteries), now press the volume down button on the television (on the actual tv). If this works it's time for a new remote, if this doesn't work then if could be that the panel in the tv (inside the television set, on a circuit board, where the volume button is) has gone faulty or it could be a software issue with your tv.
Sep 05, 2013 | Televison & Video
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
Volume automatically goes to the loudest
There should be a setting that allows you to set the "Power On" volume level. Check the menu Under Volume settings.
What is the make and model of the Television set?
Nov 22, 2012 | RCA Televison & Video
My Akura TV has suddenly lost most of its volume power, everything else works fine.
i have an akura combi and the sound has just gone off , the remote is going up and down the volume scale but still no sound, please help.
Aug 12, 2012 | Televison & Video
Hi i have a samsung galaxy s GT-i9003. I am unable to unlock by pattern lock. I haven't set up my gmail account yet on my phone
The only way to get around this is run the recovery
How to do this
1. Turn off the phone
2. Told down the UP Volume button and power button
3. Wait till the screen comes on and then off
4. A menu shows up and click restore/recover
5. The password is gone.
May 06, 2011 | Samsung Galaxy S GTI9000 Smartphone
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Open Questions:
Televison & Video Logo
325 people viewed this question
Henry  Thomas
Henry Thomas
