Question about Akai LCT3201AD 32 in. LCD Television
Akai pt50dl24x dlp. my sound becomes garbled and crackly and then silent after 1/2 hr. i turn it off for a while and it works for a bit and the problem returns. what do i need? a sound card? help
  • 3 more comments
  • binkley75040 May 26, 2011
    why does your response reference the Akai LCT3201ad ? my question is for a pt50dl24x.
    do you know the board number for my set? Where is this board and what does it look like? i managed an electronics shop and have access to some talented soldering personnel.
    akai pt50dl24x dlp. my sound becomes garbled and crackly and then silent after 1/2 hr. i turn it off for a while and it works for a bit and the problem returns.
    If i need to replace the board does anyone know the part number. if it is the Amplifier chip...does anyone know the part number and or where to get it
  • binkley75040 May 28, 2011
    is the final amplifier chip on the SAMSUNG/VIORE BP94-02262D MAIN CBA
    question: do any of you experts know this tv. telling me i need a sound card is very obvious
    an expert would tell me:
    "dave the sound card for your Akai pt50dl24x/sms is part number: xxxx"
    Question 1: Is the amplifier chip located on
    board part number: bp97-01082g
    Question 2: is the amplifier chip possibly locate on board number: bp94-02269a?
    Question 3: is the chip locatd on the main powr board?
    this is all i need to know. please DO NOT RESPOND WITH "it may be your sound card"
    I will conduct asearch to find the board. WHICH BOARD IS IT?????
  • binkley75040 May 31, 2011
    Eureka! i fixed it. after pulling the cover off and inspecting the board, i get frustrated and put everything back together. i left the cover off and turned it on to make sure i put all the cables back properly etc.... It played flawlessly for over two hours. put the cover on and after twenty minutes the problem returned. i bought a cheap ten inch fan from walmart and clipped it to the back of the set and aimed the air low into the vent holes..........The Tv was left on for over 12 hours and worked perfectly. Granted, this is not a high tech solution...but for $8 a very inexpensive one. Hope other readers find this helpful
  • 373 Answers
Here is the audio IC at the partstore.com
http://www.partstore.com/Part/Samsung/Samsung/PT50DL24XSMS/Samsung/Samsung/1204002471/New.aspx
You will have to unsolder it and solder in the new one. Should be located on the signal board.
Posted on May 28, 2011
  • TV Doctor
    TV Doctor May 29, 2011
    Please accept my solution
  • 1,238 Answers
Good day!
If the sounds is crackly and then after the few minutes become silent.
yes,the problem could be the sound card but before you replaced it try to check all the boards if any leak/bulged on the top capacitors and try to replaced it before you replaced the sound card.
Thank you and don't forget to rate my answer.
    Top Expert:
  • Akai Master
  • 75,591 Answers
Hello
Sound output IC at the sound card has damaged. You have to replce the sound card itself. OK.
Posted on May 26, 2011
  • The Knight
    The Knight May 28, 2011
    Replace it and check the speakers also. If that IC is shorted, there is a chance to get its voice coil damaged. OK. Anyway, card replacement is best.
  • Akai Master
  • 11,800 Answers
The final audio amplifier overheats and malfunctions - you will have to replace it. You could replace just the amplifier chip - but that requires good soldering skills - or you could replace the entire board - but finding one will be difficult, i couldn't find one online.
I HAVE AKAI PT50DL24XISMS IT COMES ON FOR 30SEC TO 1MIN THE PICTUREGOES OUT THE SOUND STAY ON THEN GOES OFF
Its a DLP that uses a lamp, lamp is possible but I would also look to see if fans are on and running, a fan stopping or even slowing down can trigger the set off also.
Average lamp life is 2000 hours or two years and set if lamp a bit dim may shut set off.
Dec 18, 2012 | Akai PT5598HD 55" Rear Projection...
I need a lamp for Akai Model PT50DL24X/sms Lamp Code BP96-01472A (P132W) I need to find this lamp can you help? Akai does not answer e-mails & the phone is blocked ,Thanks
The bp96-01472 tells me the set was made by Samsung---lamp should be easy to find=============GOOGLE that number with the word lamp after it and you will find many places that sell it.
Two ways here, buy a generic "bulb", take the cartridge with the bulb apart etc, these generic lamps cost less but are no bargain as they usually have a shorter life span.
Get a lamp with the cartridge (bulb and housing) and your task will be easy.
Samsung bought the Akai name some years ago, all products with that name are Samsung.
When changing the lamp do not touch the glass face with your hands as any oil will cause the lamp to fail very quickly.
If you have any questions post a comment here and I will reply, the site will email me.
SD TECH
Apr 16, 2011 | Akai PT50DL24 50" DLP TV
Turn off sound when heartrate drops
On the screen just prior to work-out mode:
1. Select Settings using the right buttons and the OK button.
2. Select HR Alarm.
3. Select Off.
4. Press the OK button.
5. Press OK again to start exercise.
The same can be done during exercise by hold the OK button down to get to the menu. Very convenient when you use the alarm sometimes and have left it on.
Jul 01, 2010 | Polar F11 Heart Rate Monitor
Akai model PT50DL24X/SMS when you turn on the set it makes a popping sound then there is no sound at all. the only way to get it back is to unplug it and let it reset.
the popping sound is generated in the audio output amplifier IC, change out the ic and any associated electrolytic capacitors this should restore normal operation good luck
Jan 29, 2010 | Televison & Video
How to factory reset akai ds8341 camera. I see garbled images on the 2.5 inch lcd monitor
Two ways... 1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2.Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 23, 2009 | Akai DC6371 Digital Camera
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Pdp42z5ta AKAI Problem
Write a workorder statinf the television cannot be repaired - return it to the customer then have the customer call 800-726-4005 - and request an exchange.
Mar 12, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai LCT3201AD 32 in. LCD Television Logo
123 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
