Question about Garden
Is there an attachment available for 1/4" drip systems that will produce a circular spray pattern between 10 and 12 inches in diameter?
  • 1,383 Answers
You could try a fogger or mister tip they produce a fin mist.. home depot had them.. you might want to ask one of there guys, i have a hard time finding them when i go to look.. jay.. the guy in Florida that repairs pumps in longwood
Posted on May 26, 2011
What is the torque spec for oil pan on 1989 Lincoln town car
On the 1/4-inch bolts..........72 to 108 in-lbs.
On the 5/16-inch bolts........108 to 132 in-lbs.
Remember to start in the center and work your way out in a circular pattern.
Apr 23, 2015 | Lincoln Cars & Trucks
How to adjust the spray pattern on the 570 series pop up
Change the nozzle. If it is an adjustable nozzle change it to a fixed spray with the desired radius. 1/4, 1/3, 1/2, 2/3, 3/4 patterns are available.
Mar 25, 2014 | Toro 570Z Pro Series Black Pop-Up...
21 cm saw blade
21 cm is 8-1/4 inches. You could use an 8 inch blade or 7-1/4. But the diameter of the blade is not the critical thing. You must have a correctly fitting hole in the blade to mount on the saw shaft. Standard English size of the hole is 5/8 inch. Just take your saw with you to the store and try a blade on it. If the hole is a nice fit, your are good! (You posted this under circular saws, so I assume your saw is portable.)
Feb 26, 2013 | Saws
Can a jig saw rip fence (Skil rip fence model No. 94500), with adjustment on the shaft from zero to five inches, be used to make a circular cut with a 8 inch radius (i.e., a 16 inch diameter cutout)?
no, will never happen. Make yourself a jig, 1/4" plywood set on your table top woth a small brad set 4" from blade. make a tiny hole in board to be cut into circle, spin the board on the brad, and look a wagon wheel.
Mar 11, 2011 | Skil 94500 Jig Saw Rip Fence
Where is the heater blower motor on a 1979 Z28 Chevy Camaro located? How do you change it?
Under the dashtowards the passenger side , get on the floor and look ,you cant miss it,Once you see it you will never forget where its at. Make sure you have a good light of some kind, You will see the screws around the motor in a circular pattern about 1/4 inch or 5/16 in size, once you get them out the motor pulls right out,there will be a plug attached and remove it.
Mar 07, 2011 | Heating & Cooling
If a lead pipe 1/4in.thick has an inner diameter of 1/2in.,find the number of cubic inches of lead in a pipe 10ft.long
A pipe can be seen as two cylinders, one of "air" sitting inside the other, in this case lead.
To get the volume of a pipe you thus subtract the volume of the "air" cylinder from that of the lead cylinder.
Volume of a cylinder = area of circular cross section (or pi times square of the radius) times the height (or length) => ? * r2 * h
Volume of a pipe = Volume of cylinder 1 (outer diameter) - volume of cylinder 2 (inner diameter).
In this case; Volume of outer cylinder => inner diameter 1/2" (0.5") + pipe thickness 1/4" (0.25") = 3/4" (0.75") divided by 2 to get radius = 0.375".
3.14 (?) * 0.375 * 0.375 * 120(10 feet) = 53.01438 in3
Volume of inner cylinder => inner diameter 1/2" (0.5") divided by 2 to get radius = 0.25".
3.14 (?) * 0.25 * 0.25 * 120(10 feet) = 23.56194 in3
Volume of lead in this pipe = 53.01438 - 23.56194 = 29.45244 in3
Hope this helps ;)
Jan 27, 2011 | Computers & Internet
Need to find a new alum&copper heatsink and fan combo
This is a standard micro atx board. The holes you are seeing will be on any 478 mobo, you just have to remove the black bracket, which is usually achieved by lifting the center pin in each of the corners.
Sep 02, 2009 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
