Question about Krups FDE3-12 Sandwich Maker
There is no power when we plug it in...it does not get hot at all... it happened all of a sudden
My TV cut off by itself.
I'm not a repairman, but I do know that a lot of sudden power-offs happen due to overheating. If an electronic device gets too hot, it has a auto shut off function that kicks in. Try unplugging it for 10-30 minutes and then try it. If its plugged into a surge protector, try plugging it directly into the wall outlet.
Aug 31, 2014 | Vizio VO420E 42 in. LCD TV
Iron does not get hot
Mine just did the same thing, I think the controller fried. There is aburnt smell coming from it
Aug 03, 2012 | Euro-Pro Shark GI490 Iron
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My 82 GPZ/kz750 4 doesn't sound right - # 2 cylinder plug white
yes it could be a valve problem.
Check the valve clearances
Do a cylnder compression test
Check for air leaks in the intake boots
Apr 30, 2010 | 1981 kawasaki KZ 1300 A3
TV shutdown itself. LED on/off indicator is blinking.
That happened to me before. I was watching TV and all the sudden it would just turn off on me. The power switch had gone bad and I had to have a new one put in.
Jul 16, 2009 | Toshiba TP55F80/81 55" Rear Projection...
My 2002 pt cruiser lost power steering suddenly
check to see if the serpantine belt is still there. It sounds like like it broke. this belt runs all of the accesories on the vehicle including the water pump. So if this happened it probably starting running hot too
Jun 23, 2009 | 2002 Chrysler PT Cruiser
Xbox 360: Power Light Turns On, Ring of Light Doesn't
Try to take it back for the warranty if they don't let you there is a different way it's to put a towel over your xbox 360 but i don't recomend you doing that because if it gets too hot it might start a fire in your house.
Apr 03, 2009 | Microsoft Xbox 360 Console
Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
rjjs
May 16, 2008 | Hoover Vacuums
My K810i suddenly became very hot. It wasn't near a hot surface or in ant direct heat. I took out the battery, which was very hot. After a while it had cooled down. On replacing the battery and trying to...
Chances are that your battery has fried. But before you buy a new one try leaving the battery out of the phone overnight. Then put it back in the phone and plug the charger in. Even if nothing seems to be happening leave it plugged in for a few hours. Sometimes, it takes a bit of time till the charging begins (I have seen this happen on rare occasions). Worth trying before you buy a bew battery.
Mar 24, 2008 | Lands Phones
Krups FDE3-12 Sandwich Maker Logo
75 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
