Question about Canon PIXMA MP190 All-In-One InkJet Printer
Hello, my printer is able to scan and copy but it doesn't print. Both the cartridge lights are blinking but their is sufficient ink the cartridge. Can you help? I have Cannon MP190. Thanks
    Problem Solver:
  • 5 Answers
If the lights are blinking for the cartridges, then there is not enough ink.
Get new ones or refilled ones and try it again.
Or there may be enough ink, but the electronics on the carts are not working, could be a short, or an open circuit.
Posted on May 26, 2011
Printer won't scan because it's out of ink
Unfortunately, all-in-one printers are printers/copiers. The scan to a computer function is a secondary function and the unit has interlocks to keep it from being damaged when the ink is out. There is a way to print with only one ink cartridge in place but this only allows print jobs from the computer. The copy and scan functions are locked. For details, see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673672&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3742086#N2374 . See the section on Ink Level Indicator (!) and the bottom notch of the indicator blink fast and the Workaround: Print in ink-backup mode
You need a stand-alone scanner if you routinely want to scan to your computer without a printer ink level OK status report.
I wish that I had better news for you.
May 23, 2012 | HP F4480 All-In-One Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Our Lexmark Prospect Pro205 has sufficient ink in the black cartridge. The error message says there is interference with the black ink cartridge. Black ink does not print, but color inks print.
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at http://bit.ly/p205fw, will help fix print quality issues.
May 02, 2011 | Lexmark Prospect Pro205 Wireless...
My "ink not sufficient" button is blinking but the
Hello
I believe the ink cartridge should have ink but not sufficient for printing, if the cartridge is expensive why dont you re-fill it, re-filling is very low cost option.
Also clean the contacts of cartridge from both ends.
Hope this helps, if so do rate the solution Good Luck
Jan 11, 2011 | HP DeskJet 990cxi InkJet Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
I can't print.
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 06, 2009 | HP Photosmart C3150 Printer
Printer wont print, computer communication error that wont send information to the printer, but the scanner will scan to the computer. Power light on the printer blinks 2 times, pause, blinks once, pause,...
“All lights blinking” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still. If it an All-in-One it still scans though. This could be as a result of eithe of these of scenarios.
i. Ink cartridge has developed incompatibility. Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue.
Dec 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
186 people viewed this question
old marine
old marine
