Showing double picture with a green glow - Televison & Video
  • 927 Answers
Good Day, pklove;
Green glow and double picture? Sounds like you may own a Phillips/Magnavox. If you do the TV has an convergence problem and a picture tube fluid problem.
I would say that you should call an Authorized Service Center to come to your home and give an estimate before any service is rendered.
Good Luck, big IRISH.
Posted on Aug 16, 2008
I have a phillips 55pw9363 my picture is hazy. It does not change when I adjust the brightness.
Tv pictures and screen brightness are dulls and have a halo glow to it wright?Yes.The tv CRTS TUBES guns have a chemical call CRTS TUBES coolants are contaminated require changing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a chemical coolant kit to replace it.Kit also came with a tutoring DVD disc showing u how to replace the CRTS TUBES guns coolant chemical.
Apr 03, 2011 | Philips 55PW9363 55" Rear Projection...
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
When picture is showing it is like the picture is oval and the writing the green and red are seperated . The facial features are like they glow
The convergence board is bad if you cannot adjust, using your customer control through the menu. Also known as the small signal board.......Take your glasses off take two aspirins and see a tech in the morning!
Aug 13, 2009 | Philips Magnavox 9P6034C 60" Rear...
THE COLORS RED &GREEN ARE NOT LINE UP SHOWING DOUBLES
My Phillips 55 inch televison comes on but no picture or sounds and the on and off button flashes.
Aug 05, 2009 | RCA Televison & Video
56 inch projection tv
This is a convergence problem. If you would please post the make and model, I can provide you with some details about the probable defective parts etc.
Thanks,
Dan
Sep 08, 2008 | Akai Televison & Video
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
ICS Convergence
Did you also check to make sure both pico fuse are good ?
Jun 09, 2008 | Toshiba 50H71 50" Rear Projection...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
