Question about Garden
Starter cord jammed on my mcculloch cabrio 433l strimmer, only pulling a few inches
  • 2,510 Answers
First remove the spark plug and see if the starter can be pulled without the plug in place. If it cannot, any job that involves a recoil starter is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Check the cord is not off the pulley or is frayed and caught on something. See if the starter will operate when it is removed from the motor.
If you need to renew the cord, insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
Posted on May 26, 2011
  • 1,384 Answers
Kool you have the one with the starter on the back of the motor ! take off the starter ,pull on it to see if it is the starter or if the motor is locked up, ...BUT FIRST .....it may be hydro locked .. so first take out the spark plug. THE JUG IS FULL OF GAS....Jay
Mcculloch 250 LS strimmer pull start jammed inside and wont move
Recommend you contact your nearest authorized service center, or contact the manufacturer directly by clicking here:
User manuals
Aug 13, 2017 | McCulloch Garden
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Mitox 250-c strimmer pull cord
The starter pulley looks fine, however the small starter pawl and spring is missing rom the starter cup on the crank, it should be retained with a c clip from behind the cup
May 01, 2013 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Instuctions on how to start mcculloch generator 1800 w
I have one.. great little unit.. very reliable..
I am a wannabee diy guy.. so good luck
1 assuming sparkplug is good / in / /newish??
Fuel needs to be filled.. I suggest premium only (less residue if it sits for long.)
fill oil.. top up..
d/c electric plugs
then
togle ignition switch to on
turn fuel cap to on
turn fuel switch (sw) to on
move choke to start if engine is cold start.
pull starter cord ..
good luck
ps.. I have learned to run engine dry of fuel after use. turn off fuel (sw).. this empties carb.. You may have to pull starter cord a few times with next start to bring the fuel down..
Sep 24, 2010 | McCulloch 2000W Inverter Digital...
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch Cabrio 433l Petrol Strimmer & Edge Cutter which starts ok but the throttle doesnt work i cant get the case open to investigate the problem to ascetain what is causing the problem the...
If its the same as mine, you need to take off the air filter cover (two allen keys) and then you will probably see that the throttle cable has come out of its fixing on the carb. Hook back in and away you go!
May 15, 2010 | McCulloch Garden
Strimmer Starter strip
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
Jan 01, 2009 | Garden
Garden Logo
501 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
