Question about Craftsman Garden
Engine does not crank over properly, even after replacing starter and battery, it kicks back without making a full revolution!
  • 1,383 Answers
Take the spark plug out, i think the carb has flooded the motor, check the oil for a gas smell
Posted on May 26, 2011
Put motor in chevrolet 1500 pickup and now engine wont crank at all, starter wont turn over
What is model year? Sometimes when you replace engine you may need the computer from donor vehicle as well? Any testing at starter motor make sure tranny is in park or neutral and parking brake is set.
Make sure battery has a full charge and connections all good? You can turn crank by hand, correct? The engine isn't seized? The starter motor usually has two voltage circuits, one comes from the battery, hot all the time. The other circuit goes hot with key in the crank position and may be wired through the neutral switch for automatic tranny. The starter motor usually grounds through engine block. So, grounds are important.
You can take starter motor off, lay it on the ground, hook up jumper cables properly from charged battery to starter motor, at the least, it should kick out drive gear and spin.
Nov 05, 2017 | Chevrolet Cars & Trucks
Change my starter in a 2005 Acura TL hear a click but the starter is not turn over or engaging can some please give me advice
Make sure battery has a full charge and connections good. Make sure engine isn't froze up. Two voltage circuits at the starter motor, one comes from battery, hot all the time. The other goes hot with key in the crank position. It grounds through the engine block.
Any testing at the starter make sure tranny is in park or neutral and parking brake is set.
The starter motor itself may have a problem? You may be able to remove starter lay it on the ground, hook up jumper cables properly from starter motor to battery. At the least it should kick out the drive gear and spin, of course that is a no load test. Some of the national brand autostores will test the starter for you, if you take it to them.
May 27, 2017 | Acura Cars & Trucks
1989 chev astro lights work changed the starter ,still won't start?
Make sure battery has a full charge and battery connections all good.
If it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs, if spark everywhere, use a gage and check proper fuel pressure. Also check fuel injector pulse. Any applicable trouble codes?
If the starter motor won't even crank the engine? Two voltage circuits to starter motor, one comes from the battery, hot all the time. The other circuit goes hot with key in the start position and is probably wired through neutral switch for auto tranny. The starter motor grounds through engine block.
Mar 18, 2017 | Cars & Trucks
1999 ford explorer wont start. battery is new.wont start when jumped. it tries to turn over but barely. then only hear a click. when you turn the key the dash lights and radio lights flicker on an
Sounds like starter motor given your slow to no turnover, I assume your new battery has full charge, if not, check with meter, it may be a defective battery, or another issue with connections, did you clean cable connections when you put in new battery? I assume your engine was running properly before battery change and is not partially seized due to overheating or low oil.
Good luck,
Asthma-Free-Home.com
Nov 16, 2014 | Cars & Trucks
New tdi starter weak turns slow
Sometimes battery cables can short the circuit; try getting them away from any metal or each other.
Feb 14, 2014 | Volkswagen Jetta Cars & Trucks
Won't start. won't even crank when key turned.
no cranks, (A/T or M/T?)(
battery lugs cleaned?
Key turned on , CEL glows in dash, Check engine light>? yes, good.
does car crank jumper cable started.??????
if yes, your battery is bad or discharged, (good batteries can just be discharged, discharged dont make them bad, only dead or weak)
if ,jumper fails, to crank it fast.
then hot wire the solenoid (on side of starter caseing)
key in pocket, '
jump the big lug to the very tiny lug on the solenoid
cranks , not? bad starter
yes cranks but dont run, good, key is in pocket for safety, this is normal
but the KEY line is dead.
bad PRNDL switch
see the tricks section here
http://www.fixkick.com/nocrank.html#tricks
Jan 18, 2014 | 2004 Jeep Liberty
Wont start. wont even crank.
Do you have power at the starter terminals ?
Could be something between the starter and the key switch such as the neutral safety switch.
2002 ford ranger wont turn over?
Are you saying the engine will not crank, or not start ?
May 29, 2013 | 2002 Ford Ranger Regular Cab
01 Mazda 626 I4 not starting after overheat/head gasket replacement
I would almost have to be there in person to advise.
I doubt anything happened to the starter as a result of the engine overheating.
One of the pistons or cylinder walls could have warped when it overheated which would cause a difficult crank, but you should have noticed it when you turned it by hand.
Its possible the timing is off, even possible something broke after you got it all back together.
I would probably start by pulling the plugs and making sure it is not a compression problem. Also try turning the crank by hand to see if the engine is tight.
Dec 24, 2012 | 2001 Mazda 626
My 96 jeep Laredo will not turn over. I've checked
sorry turns over means ZERO
the crank shaft can spin or not
the starter can in fact spin and crankshaft not.
and some think turns over means, engine runs. now that fact makes turns over, a dead statement.
the word is cranks over, the engine cranks over robustlyl
and then the engine runs.
then runs for more that 3 seconds, and the ASD relay holds. (step by step his works like this ,93 to now)
wont crank ? (clear statement in fact)
cranks ok, (crank shaft spins fast) can be seen and heard.
runs for 3 seconds? and stalls (ASD relay drop out) can be seen.
runs for 5min and stalls. (complex)
runs for hours and stalls. (even more complex)
all are key facts to the solution.
tell more..... tell all it does good bad or ugly
for better suggestions!
Jun 06, 2012 | 1996 Jeep Grand Cherokee
Garden Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
