Question about GerixSoft IndieVolume
Indievolume will not quieten down my music while using jingles through combiwave even though the mute all box is ticked. can you help me. thanks.
Trying to find out if my hp625 has an nternal microphone. Used a skype connection this morning but contact couldn't hear me. Can't fiind and hp documentation on it. ebcam worked a treat though!
Have you tried in the mixer to see if the mic is muted?
Right click on the speaker icon and open volume control, click options and select the recording button for the tick box that will show the mic input, then back on the mixer it should have a mute tick box. Uncheck that and you should have sound.
Dec 12, 2011 | Computers & Internet
The monitor doesn't have sound and microphone It doesn't play any sound ,music or tones
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it:
if your computer came with a motherboard disc the sound drivers could be on it:
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps:
Jul 07, 2011 | Computers & Internet
I want to off the microphone of this speaker but I don't know how. The speaker emits a sound like that of a microphone and it disturbs our listening to music.
if you want to off the microphone
click start control panel sounds and audio devices select advanced there you can a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has or has'nt got a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has'nt a tick in it
click start control panel sounds and audio devices select advanced there might not be a tick in the mute box tick it although it should not interfere with any listening to your music there might be another issue
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 26, 2011 | Altec Lansing VS2421 2.1 Speakers
One message said no microphone & one said it was muted
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Apr 22, 2011 | Computers & Internet
I'm trying to connect my headphone/microphone to my pc but no any option gets shown after connecting headphone to pc neither any sound is audible to headphone though speakers are working !
i dont think anything will show on your computer unless you are using an internet messenger program yahoo or skype or something similiar you will have to do this manually
Apr 18, 2011 | Gigabyte Computers & Internet
Creative A60 speakers no sound or from the headphones even though the speakers light is on and the volume is on 'high'. Whats wrong?
hope this helps
don
Feb 21, 2011 | HP Audio Players & Recorders
Please provide me step by step instruction about the installation of a headset to my PC. My mouthpiece does not work due to installment problem but the speakers work well. Thank you. I look forward to...
the headset should have 2 plugs one green one red they usually plug into the back of the computer with the speaker plug in the middle you could alternate these also make sure the microphone settings are correct
hope this helps
don
Feb 19, 2011 | Computers & Internet
Mic not working
hope this helps
Feb 07, 2011 | Milwaukee Tool Case Heat Gun
I have a problem can someone help me please i had my headphones on and somebody touch me and from the static of the bodies my headphones only worked on one ear i bought new headphones thinking that that...
you might have to tick the mute box the try your microphone first before unticking the mute box
hope this helps
Dec 10, 2010 | HP Computers & Internet
When using skype people at the other end cant here me very well my laptop is a toshiba satellite pro s300
if you are using a headphone with microphone attached
control panel sounds and audio devices select advanced there might be a tick in the mute box untick or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
or you might have to tick in the mute box try to make a skype call then untick the mute box
or
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment
hope this helps
Nov 14, 2010 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top GerixSoft Computers & Internet Experts
David Payne
David Payne
Are you a GerixSoft Computer and Internet Expert? Answer questions, earn points and help others
