Question about Garden
Robin weedeater bump feed, how do I replace the line?
panilling9
  • 284 Answers
SOURCE: Replace head
be sure it is wound properly in the correct direction and no bigger than .080 line?
Posted on May 26, 2009
  • 33 Answers
SOURCE: I have weedeater model XT 85 and the spring is
if its still under warrenty take it back usually the repair cost is more than a new one unfortuately its a disposible world
Posted on Aug 10, 2009
SOURCE: Trying to replace the line in weedeater Twist/Edgs
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Posted on Oct 25, 2009
  • 202 Answers
SOURCE: Toro line trimmer: plastic 'bump down' button that
More than likely you can find a part at either a Toro dealer or at a store like Home Depot or the like. Chances are, tho I am not certain, a generic part will fit your machine. You will have to take the old pieces with you and compare to the ones that are on display. Good Luck!
Posted on Jan 26, 2010
SOURCE: My weedeater with auto line feed will not stop
Did you ever get an answer to this problem? I'd like to know because I have the same problem with my cordless 14" Black N Decker Gass Hog. I rethread it, but the line continually feeds and is out in about 2 minutes.
Posted on Aug 14, 2010
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
I have a homelite weedeater i need the carb screw settings to adjust the carb
A good starting point is from a lightly seated position, back the Hi and Lo needles out about 1.5 turns each. From that point you can fine tune the machine.
This will help you:
http://www.zamacarb.com/tipspage.html
Aug 27, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Weedeater quick snap line spool
the part you bump on the ground to feed new line unscrews but typically its left hand threads so you think you are tightening but actually loosening. once off the spool chould come out then you may can tap on the head with a hammer coaxing it to come off.
Aug 04, 2009 | Garden
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Ryobi 725R weedeater
First unscrew the bump line leter outer. Then remove the yellow line holder, you will see 2 line grooves for each of 2 lines you will wind into the spool. You will see an inlet area at each of the 2 line holders, you will take about 8-10 feet of line and thread the line into the the groove inlet it will poke out the top of the spool. You will see 2 small holes on the top of the spool, feed just the tip of the line into the hole and pull the line tight on the groove side. Do this on both grooves on the spool, once the line is secure, fish each line into the holes on the spool head and secure with the bump spool leter outer. After spool is secure take the entire spool and wind back into the spool head. you will see the line wind into the spool. make sure you wind the right direction. Once you have seen how this is done, look at the bottom of your assembled spool and you will see 2 arrows. If you have no line in the spool, line up the arrows and take 8-10 feet of line and feed as you did when you have the spool removed. The line should feed through the spool and the line will stick up from the bottom, turn the line and feed just the tip of the line into the retainer hole and pull tight from the spool let-out, once secure wind line back into the spool. Once you have done this once its very easy to do over and over!!!
Jul 21, 2008 | Electrical Supplies
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
