Question about Cannondale Lefty Alloy Dlr Mountain Bike Fork Shock 110
Where are the adstments on lefty to stiffen it up made on all mountain 800
  • 4 Answers
You need to inflate the fork to make it stiffer. There's a schrader valve under the fork leg. For best performance, set the air pressure in your Lefty so the sag is 22-33mm when you sit normally on the bike.
Posted on Apr 30, 2014
  • Jan Andreas Knudsen Apr 30, 2014
    Brigadier General:
  • 8,546 Answers
Cannondale.com
Posted on May 26, 2011
How do I fix an oil leak on my cannondale lefty
First try to replace the oil and replace the oil seals then inspect the tubes for scratching/gouging while you have them apart.
Sep 25, 2014 | Cannondale Lefty Alloy Dlr Mountain Bike...
Replace original bike seat
Lefty loosey, righty tighty. Counter clockwise. Also, check to see if the bolt is rusty because it may be seized. Some penetrating oil can help in this instance.
Mar 03, 2014 | Trek Navigator 300
Shipping a bike. dismantling instructions; front fork in particular
Since there are a lot of varieties of the Lefty go here and search the list for "LEFTY".
http://www.cannondale.com/manuals
Or you might just get away with deflating the pressure preload and collapsing the fork.
Jul 02, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
I just bought a used Cannondale lefty fork. I was told that it can be stiffened by placing a pump on the bottom of the valve to add air into the fork. Problem is, the valve stem is so encased in the fork...
Hello ledpencil,
Pneumatic bike shocks require a special type of pump called a "shock pump" that is a high-pressure (up to 300psi!) but low-volume pump. They come with a very accurate gauge, pump handle, and a bleed valve/button to let off puffs of air to soften the shock. They also have a long flexible neck that screws onto the valve at the base of the fork. They're relatively small and moderately priced ($20-$40) and can be packed in a riding pack in case you want to change the stiffness on the fly. Here's a link to some online: http://www.jensonusa.com/store/sub/292-Pumps+And+Co2+Inflation-Shock+Pumps.aspx?s=1559&mfg=0&closeoutHotdeal=&use=&sort=Default&show=25&pricemin=0&pricemax=100
Hope this helps! -The Chicken
Apr 01, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
Can i stiffen up the tension in my front forks on my mgx dxr?
Sorry to inform you, but there is no adjustments available for the forks that come with your bike. Adjustable forks (just the fork) start in around $250-.
On the positive side since there is not adjustment capability the fork does not need regular servicing like the adjustable forks.
Dec 01, 2010 | Mongoose MGX Maxim Dual Suspension...
How to dismantle lefty
Hi!
The Cannondale Lefty fork can only be disassembled with speciality tools. You can read illustrated instructions here: http://www.gordlaw.com/index.php?Cycling:Cannondale_Lefty_DLR
Please check that your Lefty fork is identical to the one described, as the process and tools are different for the various Lefty editions.
As a warning, dismantling the fork could lead to serious injury if you don't know what you are doing. Please read through and understand all instructions before deciding whether to do it or not. Good luck.
Apr 04, 2010 | Cannondale Road Mountain Bike Bicycle U...
How to get fan off water pump
go to auto store and rent a speacial tool for removing the large nut on the back side of the fan. the threads are lefty-tighty and righty-loosey. leave belt on to help hold fan.
Dec 27, 2009 | 1997 Mercury Mountaineer
Cannondale Lefty Alloy Dlr Mountain Bike Fork Shock 110 Logo
428 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
