Question about LG Dryers
Ld gas dryer m/n glg2522w runs but no heat have gas to dryer and do not hear clicking sound that ing
    Brigadier General:
  • 3,301 Answers
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Inglis 82000 Dryer. No heat, but working otherwise. Where do I find the fuse in the dryer to check?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Whirlpool Inglis IP8200 Dryer
Inglis gas dryer heat wont stay on
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas saefty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 31, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Inglis Gas Dryer Does not heat up at all, No spark, no flame
When you start the dryer , after a few seconds do you hear a distinct click sound from inside the bottom of the dryer at the burner assembly? If you do not, you most likely have a bad thermal fuse, part# 3392519 or 3390719, depending on your dryer. Its the same fuse just different shape, both will work. This is most likely your problem. If you do hear a click, you may have a bad ignitor. Best way to test is to check for 120 at the ignitor. If you have anymore questions or need parts feel free to ask in my forum at www.washermd.com, thanks, Dave
Nov 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
46 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
