Question about LG LRM1230W Microwave Oven
Carasel motor shaft broke off in collar of rotationg ring. Cannot get broken shaft out. Drilled hole and inserted screw but screw pulls out.
  • Ray Lenz May 28, 2011
    In this situation the motor shaft somehow became bonded into the collar of the rotating turn table in the microwave. I even tried to use a brake adjusting too as a lever to pry the turn table off. I wasn't sure that it should have come off or I would pried with more force. The shaft was sheared off of the motor evidently because the carousel was bound and wouldn't turn. Nothing I did pressed the broken part it into the collar. I was trying to remove the broken portion from the bottom by drilling and inserting a screw to pull on. I later drilled a larger hole and was able to screw in a long screw that I could pull with pliers. No results. It was completely bonded into the collar. Since the motor shaft has a flat side I couldn't use an Easy Out, which I have used many times, because they work by twisting out broken screws, not by pulling straight out.
    I finally gave up and bought a new microwave, after I had purchased a replacement motor that I can't use now. I don't imagine that I can return an electrical part.
    I and 68 and learned long ago to repair almost anything from cars to computers. I have repaired several microwaves. Now things are made to throw away or so sufficicated that you need schooling and special tools to repair. I knew to search online and find the part number for the motor.
    Thanks for your reply.
  • 5,687 Answers
Hello, I usually get parts from a company called SERVALL. They have a Website,(SERVALL .com). They have been in business since 1929 and have Franchises so look in your local phonebook for nearby stores too! Before attempting to piecemeal repair you may want to see if the Manufactuer has replacement parts for this.
Sears has some easy-outs for broken bolts, some are for small sizes. If this shaft is permanently mounted in the case of your Microwave, the shaft may be part of the motor or embedded as a drivegear box. Unfortunately, when you drilled into the shaft you also pressed it into the collar.
You can try to Browser search by using the appliance name and model and add, illustrated, diagrams, shop manual, and so on for variations until you get a hit. It may be difficult to find the diagrams because people usually do not fix these themselves.
I hope my solutions include something very helpful and good-luck with this repair.
Posted on May 28, 2011
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it off with a gentle lift, watch the bottom and inside edge (Thanks Lukas Patterson). I took out the black plastic latch, drilled a hole near the broken piece and all was good. Updating, as my original fix wore out. I ordered a replacement latch prior to repairing the existing latch, same directions to gain access, just use the spring on the new latch and press on the plastic cover to re-seat.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Nov 04, 2010 | Microwave Ovens
Model is JES1451. Turntable won't turn. I removed the cover and the motor and the shaft appears to be broken. How do I remove the broken shaft and replace the motor?
Hi the shaft should just pull up, to remove the motor you will need to turn the oven onto it side, you will see a cover at the bottom of the machine to remove this you will probably need to cut through three of the tabs, you can then gain access to the two screws securing the motor.
When replacing the cover turn it over and fix using the spare self tapping screw to be found in the base near to the cover you just removed.
Hope this helps
Jan 05, 2010 | GE JES1456 Microwave Oven
My turntable quit turning, I looked in and found a what appears to be a piece of what looks like glass that acts as a shaft between the motor and the turntable was broken. I cant find the part or any...
If you are talking about the little piece that the center of the tray sits on (not the carousel ring), its called the coupler. Its actually made of plastic on all the microwave ovens I've ever worked on. I've never seen one made of glass. It connects to the turn table motor shaft. If you post back with a complete model number, I may be able to assist you in locating a part number.
If the coupler is not physically broken, you may be identifying the wrong part as your problem. The turntable is driven by a small motor which is mounted under the bottom panel of the oven. The coupler is mounted to the shaft of the motor and the glass tray sits on the coupler.
Post back and let me know if you need a coupler, or if your motor isn't turning. You can tell by removing the glass tray and pulling straight up on the coupler. It should come off the motor shaft in one piece. If its not broken, your motor probably needs replaced.
Sep 09, 2009 | Microwave Ovens
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my microwave broke away from the door. Is it
Of course it is.  You can glue it on with gorilla glue, perhaps using a screw shaft (be sure to drill pilot holes) like a dowel in carpentry to secure and add area for the glue to adhere to.  Drill the pilot hole in the handle bit the thread diameter rather than the shaft diameter, so you don't have to screw the handle on once you cut off the screw head.
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave turntable
The solution is very simple. Unplug the microwave first. Remove the round dish. Remove the circular riing with the rollers and set aside with the dish. Carefully with a butter knife, pry up the coupler and set aside. Examine to make sure it isn't broken or cracked where it slips over the motor shaft. Remove 5 Phillip head screws from the bottom pan and it hinges down out of the way exposing the motor. Remove 2 screws holding the motor, slip off the plastic dual flat connector and slip back onto a new motor $52.25 + shipping from GE parts. Remember your actual MW Model number is NOT XL-1800 but it is on a metal tag inside the MW on the left side. Put the motor screw in as removed so the shaft is free to stick up the hole in the bottom of the MW. Put the pan screws back up, put the coupler on, the ring in and then the dish and line the slots of the dish up with the star coupler so it catches. Turn on MW, touch the turntable button and make sure it is "ON" and not "OFF" and it should be, with the door shut, turning like a quiet little top as new.
Aug 19, 2008 | Microwave Ovens
LG LRM1230W Microwave Oven Logo
54 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
