Question about HP DeskJet F380 All-In-One Printer
DEFECTIVE pOWER SUPPLY aDAPTER
WHERE DO I FIND A SCHEMATIC DIAGRAM AND iC pIN cONFIGURATION
'l
Posted on Aug 17, 2008
'l
Where can I download schematic diagram or sevice manual for sharp 20V-L75M?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 23, 2014 | Sharp Televison & Video
How to make regulated power supply
The easiest way to do this is to use a 3 pin regulator IC.
For a 5 volt supply go to this WEB site,
http://schematicwiring.com/simple-electronic-applications/5v-dc-regulator-with-3-pin-regulator-circuit-schematic-diagram/
For a variable voltage power supply go to this WEB site.
http://www.engineeringslash.com/power-supply/three-terminal-adjustable-regulator.html
Mar 16, 2011 | Computers & Internet
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
Hi,my notebook is not turning on .Charging is good .When i press switch button charging process is stopping to 1-2 seconds then continues .Maybe problems in motherboard?Product Details for ASUS F5RL-X1...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 16, 2010 | ASUS F5RL-X1 Notebook
Noisy when I use with 9v charger and is not
The posts on this site will help:http://music-electronics-forum.com/t10712/ I had trouble finding the correct schematic but the one here:http://www.tonepad.com/getFile.asp?id=42 should give you an idea of what I am talking about. Using a volt ohm meter on the D.C. volts scale ,hook up the black probe to the circuit ground. Make sure to use the correct adapter as a variation in the current output. ma will blow your pedal up. The diode in the schematic with one end hooked to ground protects the circuit from adapters that are wired backwards. It is the first thing you want to check. You will have to perform a diode test. Hopefully your meter has this function. If the diode is O.K. and you can get the correct voltage ( polarity, milliamps etc.) into the circuit, have a look at the schematic. Test each I.C. for voltage at pin 8. Depending on what I.C.s are in your pedal you can find the defective one by testing for voltage at the supply pin and then the other pins of each I.C. If you find voltage at a pin that should only be carrying signal you probably have found a defective one.For instance, in the sample schematic, pin 2 of IC 1a should have no voltage present such as 9 volts for instance. Test all the diodes, test all the ICs. If they are all fine you will have to test each transistor. The info on how to do all this as well as the pin outs are all available on the internet. After you find the defective part or parts test any parts that are hooked to them in the circuit as well as they may have failed or caused the other part to fail. Before I got an oscilloscope I had to unsolder a lot of parts to test them with a VOM, a transistor tester and a capacitor tester. The repairs paid for the scope. Let me know how you make out. I don't work on effects that much any more as my eyesight is failing but I might be able to steer you in the right direction. If you decided at this point that you don't want to try the repair, take it to a good musical instrument repair place and have it fixed. Vintage pedals are getting to be worth a lot of money and they usually sound better than the reissues.
Nov 29, 2009 | MXR Phase 90 Pedal
I have a Casio PX-310 on the service bench . I
As you probably know the regulator also supplies power to the other ICs on the board. If the fuse keeps blowing that means that one of the parts drawing power is shorted. By looking the pin configuration up for each IC you can find which one is the + and which one is the- etc. The faulty IC will be showing voltages on the other pins where they shouldn't be. That is usually the defective part. You will also want to check parts that are related to or in the same circuit. The worse case scenario is that the main IC is shorted. Without the schematic its a long arduous troubleshooting procedure but it can be done and I just thought I would suggest it. I mean know pffence and just wanted to help somewhat.
Jul 09, 2009 | Music
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Blue alignment still does not work after IC replcaement
You are going to need to get a schematic diagram and trace out the resistors and capacitors in the convergence circuit or power supply as most of the time you dont need one and replaceing the IC's will fix it, but sometimes other things have went bad because of the defect in the Convergence drive IC's or one of the new ICs could be defective. Would not be the first time I have seen this problem. Did you buy tHe exact replacement IC? Did you use heat sink compond behind the IC on the heat sink? These two things are very important as well. If you dont have a multimeter and now how to us one as well as read a schematic, you may want to seek out the assistance of a pro. Good Luck PS please dont forget to rate this thread.
Oct 22, 2006 | Samsung PCN5425R 54" Rear Projection...
HP DeskJet F380 All-In-One Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
