Says printer offline but I've checked all connections
    Sergeant:
  • 167 Answers
Printer is offline because it's not connected or the printer power is off and or the printer cable is not properly connected.
if not, try to:
Go to start double click printer and faxes find the model of your printer right click your printer model then set as default printer then power off the printer and restart your computer after you login, power on the printer
Posted on May 26, 2011
  • 11,800 Answers
By all i assume you have made sure the printer is truly on (its status lights are on and it makes the usual start noises) then you tried using another USB cable plugged in another socket and you got the same result. Also you have tried connecting it to another pc and there it went also unnoticed - the New Hardware Wizard hasn't appeared because the pc hasn't detected it.
In that case the printer itself is faulty - its mainboard is no longer operational. In that case the printer is effectively dead and it will be a lot cheaper to just buy a new one than to repair it
4 Suggested Answers
  • 126 Answers
SOURCE: My brand new Canon IP
Hi, please follow this instruction to make your printer back to "online". Notice that i have used Epson Stylus Photo R230 as a model for the instruction, but this procedure also works with canon.
1. Please try to print a document. (word, excel etc.), 2. Now, if you already notice that your printer is "offline" by clicking the printers icon at the task bar.
The task bar can be found in the lower right part of your screen.
3. All you have to do is, Click on the "printer" tab 4. And then remove the check mark at "user printer offline" by clicking on it.
5. Once done, you will notice that the "use printer offline" will disappear and then let's you print the specified document again.
I hope this helps.
Posted on Aug 09, 2011
  • 1575 Answers
SOURCE: message printer offline
Hi
How about disconnecting it completely from PC and from power.
Wait a few minutes and then connect again.
Clear any paper jams and print queues.
Posted on Mar 04, 2012
SOURCE: hp2840 printer won't go online, says it is offline
you may have to contact HP expect a charge unless u are still under the 1 yr warrantee You can also goto the device manager and try to update the driver
Posted on Aug 14, 2012
Hp 3847 printer lost communication with the computer
Hi, Need more information. Connecting by Wireless or USB? When installing does it find printer correctly?
Jul 13, 2017 | Office Equipment & Supplies
Printer says it offline
It probably changed its IP address. Try uninstalling its driver and re installing it. Some smart drivers automatically detects their printers once connected on a router.
Also check connection from device manager .....
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 28, 2012 | Office Equipment & Supplies
Hi, My Star TSP100 printer always goes offline after computer shutdown
Hi Valued Star Customer
It seems like the USB host may be going into "sleep mode" and not awakening. Please contact Star Support at support@star-emea.com for documentation.
Best regards
Star Technical Support
Feb 13, 2012 | Star Micronics TSP100 Thermal Printer
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
My brand new Canon IP 100 pixma printer wont print cause it's saying "offline." I've turned it off and on numerous times. What can i do?
I hope this helps.
Aug 09, 2011 | Canon Office Equipment & Supplies
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
My HP P2035N LaserJet is saying it's "offline"
Offline means that the computer thinks the printer is not available. The problem is that some how, that option in the printer menu has been checked. "use printer offline" is the choice that has probably been checked. Some times this will happen after a communication or paper problem has occcured.
To get to this menu, go to printers and faxes on the control panel. Find your printer icon and click on it.
A window wil appear and you will see file in the upper left corner. Click on this and a drop down menu will appear. You should see the offline option here, and if there is a check mark in front of it, click on the check mark to remove it.
This should clear the problem.
May 24, 2011 | HP P2035N LaserJet Monochrome Printer
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
DEVICE STATUS OFFLINE
To solve this problem you'll need setup the printer up with LPR Protocol. Go to Devices and Printers. Right-click on the printer in question select Printer Properties. Go to the Ports tab. Find the port you've setup then click on Configure Port. In the block titled Port Name you'll need to enter the name of the Gigafast Print Server. It's normally 1P_PrintServ??????. The ?s are the last six entries of the print server's MAC address. Next, in the Printer Name or IP Address enter the assigned IP address, example (192.168.5.3). For the Protocol select LPR. LPR Settings: Queue Name: same as 1P_PrintServ??????. Lastly, check the box that says LPR Byte Counting Enabled. Now when you shutdown and restart the printer will remain online.
Apr 15, 2007 | GigaFast Ethernet EE171-PR Print Server
91 people viewed this question
jasbo
jasbo
