Question about Xerox WorkCentre 4150 All-In-One Laser Printer
I have a 4150 error: system fault: 0, file http_Device status.c, line 4738 task CSWS
2 Suggested Answers
SOURCE: system fault o file osal-psos-c,line1582,task jmts
bad hard drive or firmware call service to reload
Posted on May 28, 2009
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
WINDOWS 7 32 BIT CANT FIND DRIVERS KEEP CRASHING MORE INFO ; PC-7 Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130708-1532) Language:...
If you want a detailed information on the crash
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
also
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Then give your computer a tune up.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Sep 12, 2013 | Computers & Internet
Hp designjet 500 plus 42 is showing severe error 0x9010001 please help
SYSTEM ERROR 81:01 severe error: 0 x 9010001 task: interrupt file: papermotor.c line:1587
quu hago?
Nov 27, 2011 | HP Office Equipment & Supplies
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Problem: KERNEL_DATA_INPAGE_ERROR Technical information: ***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913) ***acpi.sys ? Address 806C7913 base at 80692000, DateStamp 49c01a37
The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A. This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
Parameters The four parameters that are listed in the message can have three possible meanings. If the first parameter is 1 or 2, or 3 and the third parameter is 0, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (1, 2, or 3) 2 The error status (usually an I/O status code) 3 If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
4 The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (3 or 4) 2 The error status (typically an I/O status code) 3 The address of the InPageSupport structure 4 The faulting address
Otherwise, the parameters have the following definitions.
Parameter Description 1 The address of the page table entry (PTE) 2 The error status (usually an I/O status code) 3 The PTE contents 4 The faulting address
Cause Frequently, you can determine the cause of the KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2). Some common status codes include the following:
  • 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
  • 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
  • 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose cabling, termination, or that the controller does not see the hard disk.
  • 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
  • 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination or defective cabling on SCSI devices or that two devices are trying to use the same IRQ.
These status codes are the most common ones that have specific causes. For more information about other possible status codes that can be returned, see the Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem Resolving a bad block problem: An I/O status code of 0xC000009C or 0xC000016A typically indicates that the data could not be read from the disk because of a bad block (sector). If you can restart the computer after the error, Autochk runs automatically and attempts to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run Chkdsk /f /r on the system partition. You must restart the computer before the disk scan begins. If you cannot start the computer because of the error, use the Recovery Console and run Chkdsk /r.
Warning If your system partition is formatted with the FAT file system, the long file names that the Windows operating system uses might be damaged if you use Scandisk or another MS-DOS-based hard disk tool to verify the integrity of your hard disk from MS-DOS. Always use the version of Chkdsk that matches your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware diagnostics that the system manufacturer supplies, especially the memory scanner. For more information about these procedures, see the owner's manual for your computer.
Check that all the adapter cards in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages that might help identify the device that is causing the error. You can also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can cause this error.
Resolving a virus infection: Check your computer for viruses by using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. All Windows file systems can be infected by viruses.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Xerox WorkCentre  4150 All-In-One Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
