Question about Behringer Bx4500h Ultrabass 450w Bass Amplifier
My Behringer Ultrabass BX600 has a very loud, constant hum. I tried a new power cord, and speaker along with checking the internal parts for a burn spot and tight fit to no avail.
  • Behringer Master
  • 5,603 Answers
It is likely the power amp chip has shorted. This puts the unregulated dc into the speaker and you will hear the hum. DO NOT operate this way as you can burn up the speaker. You will find that the LM3886 chip on the heatsink has failed. They are about $7.30 from Digikey. They come in two lead bent versions. Make sure to get the correct version and use heat sink grease wheen installing.
Posted on Nov 28, 2011
Can I add a 4ohm 4x10 speaker cabinet to the lineout port in back of the Behringer 3000A
No. The line out is at line level, not amplified to speaker level. Yu can run a powered cabinet, but not a passive one.
Jun 04, 2016 | Fender Music
What would cause a buzz in speakers?
There are many causes of buzz, so it should be checked step by step :
- Bad connection on the input connector, or cord.
- Amplifier, basically have the block diagram like this. View image.25850665-l1qpqmriditabltrjczr2eku-2-0.jpg
If in one block damage, buzz can be heard.In the amplifier.
Generally occurs in the PSU and / or power amplifiers.
Fix it to the experts,because it requires a good knowledge of electronics.
Blown speaker cone, does not cause a buzz.
Short circuit along the wires supplying the audio, it will not cause any sound in the speakers, including the sound of music.
Try also, disconnect the input connector, whether the buzz is still audible. If after the input connector is removed, the buzz disappears, the possibility of buzz came from another device before the amplifier.
Sep 05, 2015 | Behringer Xenyx 1202 12-input 2-bus Mixer...
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Apr 12, 2012 | Behringer Ultrabass Bxl450 45w 1x10" Bass...
As soon as I turn the volume over approximately 40W, the speaker keeps moving while making an awful sound at the same rhythm. I believe the speak may be burned. Is there a way I can fix it or I have to...
How do you know you are at 40 WATTS? This takes electronic test equipment to measure.
Tests to run. Observe the speaker cone with power off. Now turn it on... did it displace and stay there? If so you have a failure of the amplifier itself. Next, If you can place finger on the cone, move it gently in and out feeling for any roughness. If you feel roughness, the voice coil is fried and you be buying new speaker. A lot of the Ultra bass Behringer's use LM3886 power amp chips... sometimes in parallel, and a failure of one could cause this.
Aug 23, 2011 | Behringer Ultrabass Bxl3000
My bass amp Behringer bx 4500 dont have power when I turn on the switch. I check the fuse but it was fine. What could be the problem of the amp when it does not turn on?
First thing is to verify that the power cord is GOOD and that it is fully seated. Beyond that repair is NOT DIY. Take it to a repair shop.
Jan 09, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Behringerbx4500h amp has a bad hum i here the have this problem
If the hum exists with NO input cable plugged in, this requires repair, most likely in a shop familiar with the unit.
The problem may be in the unit's power supply or a broken connection inside.
This problem can also happen if one of the oputput amp transistors shorts driving out DC current into the speaker which is a grave risk to the speaker. Check the DC out of the speaker connector. If it is NOT very near zero, say less than 0.1 volts DC, do NOT copnnect speakers..
Jul 13, 2010 | Behringer Bx4500h Ultrabass 450w Bass...
Behringer's Ultrabass BXL3000 Gain knob broken
You need to replace the potentiometer with the broken shaft. You can open the unit and try to get a part number or go to Behringer parts to get an exact replacement. The pot must be matched for value, taper, and mounting and shaft dimensions.
May 23, 2010 | Behringer Ultrabass Bxl3000
Behringer Bx4500h Ultrabass 450w Bass Amplifier Logo
694 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
