Question about Toyotomi Heating & Cooling
Hi, My husband and I recently purchased a couple thru wall/window air conditioners. We are planning on putting them in our windows, but they did not come with any mounting kits. We are having a hard time finding any mounting kits to purchase. Do you have any idea where we could find some to purchase? Thanks
    Genius:
  • Toyotomi Master
  • 1,033 Answers
Hello, you can purchase mounting kits at a local heating and cooling supply store. Here is a link to a online store that carries window kits http://www.apwagner.com/index.php?main_page=index&cPath=10_48
Posted on May 26, 2011
Describe your KS15L10 Thru-Wall/Window Air Conditioner Problem My unit also runs about 10 minutes and the kick off the 15 amp breaker. Unit was purchased 2006. Any ideas
Hello my name is Heath iot will be my pleasure to assist you. The first thing to do is unpludd the unit then go out side wioth a garden house and use a strong jet of water and blow it through the coil and get it real clean if you can then try running the unit.
Aug 29, 2011 | Friedrich QuietMaster KS15L10...
I can't find one this model replaced model 74054 purchased in 6/10/93 thank you
Your message was a little confusing. But, if you're looking for the Kenmore 75050 Thru-Wall/Window AC, you can find it at Sears online at the following link.
http://www.sears.com/shc/s/p_10153_12605_04275050000P?keyword=kenmore+75050+thru-wall%2Fwindow+air+conditioner&sLevel=0&prop17=Kenmore%2075050%20Thru-Wall/Window%20Air%20Conditioner
Hope this helped you find the model you wanted. Please let me know. Thanks.
Jun 09, 2011 | Kenmore 75050 Wall/Window Air Conditioner
Air conditioner won't reset.
If you're trying to reset it right after it trips, you're not giving it enough time for the pressures to equal out.
Also, try again, unplugging it from the wall and waiting about 20 minutes before plugging it back in.
If it got a good surge from the storm, it may have grounded out the compressor.
Jul 16, 2010 | Goldstar KG6000R Window Air Conditioner
Window air conditioner
Hi, yes you can put a window unit through a wall. Just make sure that the condensation will drain from the indoor coil to the out side which it should do on its own design. Also, make sure that the condenser coil at the rear of the unit is all out side. You will have no problems at all. You can use 2- peices of small chain at each corner and use small lag bolts to secure it to the wall. Looks better then to build a frame to set it on for support. Yes, they are made to install in either place.
Best of Luck,
Shastalaker7
Jun 06, 2010 | Heating & Cooling
Leeking water from the front
flush out the drain spout /hole in the rear of the unit and tip back a couple degrees more. Eric
Aug 12, 2009 | Whirlpool ACQ068PR Thru-Wall/Window Air...
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Jun 12, 2008 | Heating & Cooling
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Heating & Cooling Logo
177 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
