My copier puts out copies that have two dark stripes along the right side of the paper. What can I do to fix it. I've replace the ink cartridge and cleaned the glass. xc830
    Scholar:
  • 56 Answers
Usually its a leakage on the cartirdge . Ill be advising you to remove the cartridges adn used a clean paper make sure its clean .Clean also the area where you put the cartridge make sure its clean .Then return it back make sure its plugged in properly close the carrier and th cover try to print again in case nothing happens .Go to the settings look for clean cartridge ..
in case still the same thing look try again in case nothing happens asked for a cartridge replacement
Posted on May 26, 2011
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
Epson stylus photo rx 500 bue color makes stripes
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 20, 2011 | Epson Office Equipment & Supplies
I replaced the black cartridge & when it said to run the alignment the paper comes out and looks like it's OK but the message comes up that slignment failed. Then if I ignore it and try to make a...
Good Luck!!!!!
Aug 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
The printer is printing dark along side the edges of the paper each time I print. I've changed the drum, but that didn't seem to help. What else can I do?
Print an empty word document, and if it still shows the dark lines on the edges the rollers are most likely caked with ink, and they will need to be cleaned.
Jun 09, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
52 people viewed this question
k24674
