My network adapter was missing and i need to install the network device so i can use my LAN cable
  • Fhearghuis
    Fhearghuis May 26, 2011
    What type of computer?
  • JDTec
    JDTec May 26, 2011
    what model, what computer?
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
hope this helps
Posted on May 26, 2011
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
I HAVE A BUILT-IN NETWORK ADAPTER IN MY COMPUTER FUJITSU, M0DEL FMV 6000CX2 HOW CAN I INSTALL IT AND MAKE IT WORK.
Normally it is automatic enable.
U can see a local network connection (LAN) icon appear under network connection. The icon will show u unplugged if u did not connect to any network or devices.
If u did not see the LAN icon, then u need to check under device manager whether there is any missing driver.
Mar 10, 2009 | Computers & Internet
Need help please help me out I DONT SEE NO LANCARD ADATORS IN NETWORK ADAPTOR UNDER DEVICE MANAGER IN PROPERTIES OF COMPUTER NOR IS THERE ANY YELLOW MARK WHICH STATS THAT ANY DRIVER IS MISSING
- Check the LAN card if properly inserted to the PCI slot of the computer
- If you a yellow mark under device manager, you'll needing to install the driver of the adapter.
- Check for the latest update driver of the adapter.
- There are two ways to install the driver:
*Install the driver using the wizard.
*Force install the driver by right clicking on the icon that has the yellow mark and click update driver.
Note: There are compatibility issue for operating system and driver using any adapters.
Mar 03, 2009 | Computers & Internet
Lan card
First of all are you sure there is one inside the computer? Secondly if it is installed inside the pc itself there may be a problem / driver not loaded. Make sure to install the drivers before trying to use your network adapter. Most of the time they come with a disk or you can download software from another computer!Have you tried another Lan Card? Just like any other PC component they can get fried.
Will not reconize ethernet cable
Please ensure the following:
1. Make sure you use the LAN port.
2. Ensure the cable is in good condition. Try using new cable.
3. Ensure you installed proper network card driver.
4. Ensure the network card using correct link speed (100Mbps).
5. Try switching the link speed to Auto, if you're not sure.
These are the basics. If possible, try installing the latest firmware for your network card. Normally, downloadable from the manufacture's site.
Regards,
Maha
Jan 16, 2009 | Microsoft Windows XP Professional
Do i have a lan card installed on my system??
Just check it in the device manager ,, goto device manager by right clicking on my computer... if u have network adapters then u have LAN ... and if u have lan u don need drivers it will be inbuilt ...
Nov 30, 2007 | Compaq 2Mbps Wireless LAN PCI Card for...
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
