Question about Brother HL-4040CN Laser Printer
Hi, we just used iron on paper in the printer, and the paper got stuck. we think it melted to the rolls on the back of the printer, the oragane and black rollers. what do we do????
    Scholar:
  • 118 Answers
Oops...You need to remove the fuser unit from the printer & attempt to carefully remove the melted paper. You can use a sharp object to get started but be very careful not to damage the surface of the heat roller. This needs to be a slow patient job but it should come off.
Otherwise you will need a new fuser unit.
Posted on May 26, 2011
How to removethe laminate fromlaminated papers
Good question because the hot melt sheets having only a melting glue on the foil that must be melting by heat but i think maybe with a razorblade or little stanley knife and an iron it should in practice possible to remove but be careful by experiments with hot irons but the glue left the foil and should be in the paper but should not sticky if its in cold condition.
Jul 08, 2017 | Office Equipment & Supplies
What problem with using iron
If you going to print for a "transfer" paper use one that meet the transfer specifications in order to get the best transfer on the surface.
s.gif s.gif s.gif s.gif » Introduction
s.gif » What you'll need to get started
s.gif » Instructions for iron on transfers
s.gif » Tips for using iron on transfers
s.gif » How-to video: See it in action
s.gif » Project ideas and examples
s.gif » More creative printing ideas
s.gif » Buy your own iron on transfer paper
s.gif » Submit your ideas
Introduction
Iron on transfers are easier to make than you might think! After showing you everything you'll need to get started, we'll give you step-by-step instructions and tips to become an iron-on expert. We'll even give you great resources for free iron on transfers!
s.gif » Back to top
  • Printer
    An inkjet compatible with iron on transfers
  • Paper
    Regular paper for printing previews of your design
Dec 07, 2010 | HP DeskJet 5550 InkJet Printer
How do i seperate the casing as the printer roll door is stuck and I need to find out why - I think I have removed all screws thanks
Open the front sliding door on the top (right in front of paper door)
Inside you will find a white wheel that rolls (looks like a gear)
Roll the wheel forward (towards you) about 50 times and that moves the cutter bar arms out of the way so that the paper door will open.---Instructions are on lid of paper door once you get it open--great place for the instructions--don't you think??
Sep 26, 2010 | Posiflex PP7000 Printer
Paper is jammed. Don't know how to get it out. (Can't find manual).
The link below will provide you with Video of how to clear Paper Jam error on printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00860153&cc=us&lc=en&dlc=en&product=3192753#N1189
Steps to resolve Paper Jam issue
1. Disconnected the power cord from back of printer.
2. Open the Rear Access Door.
3. check if there is any paper piece stuck in rollers.
4. Clean the rollers using link free cloth ( wipe rollers in same way the paper is rolled [ wipe upwards )
5. Close the rear access door
6. Open the front access door
7. Check for any paper stuck in carriage rod
8. Close the front access door.
Please remove all the paper's from paper try and re-stack the tray, make sure the papers are free and does not has moisture. Please the paper in tray
9. Connect the power cord back and power on the printer.
This should fix the issue.
Also, download the manual from the the link below
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3192753&lc=en&cc=us&dlc=en&lang=en&cc=us
Sep 07, 2010 | HP Photosmart C4280 All-in-One InkJet...
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
My daughter fed an inkjet iron on transfer and is
Sometimes paper jams (and iron on jams) can cause the paper (or iron on) to get stuck in areas that are not visible to you, usually on the sides of where the paper would go. I don't know the specifics of your particular printer, but I would take a look at the guides on the side of the paper path and there are usually several screws that you can remove or loosen so that you can verify that the paper path is clear. Hope this helps and good luck!
Mar 13, 2010 | Konica Minolta PagePro 1350W Laser Printer
Iron on paper jammed and cannot be reached to unjam and will not process thru on its on
You cannot run iron on paper through a copier. They will melt in the fuser, and then the fuser will have to be replaced. The fuser generally runs 160-190 degrees, generally about the heat of the iron.
Dec 25, 2009 | Canon imageRUNNER 2200
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Melted cordless iron to charging cradle
I don't think there is any saving this iron.
You might try heating it up again to the hottest temp. and pulling it loose, but what would you use for a chargin plate?
Mar 02, 2009 | Irons
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
Brother HL-4040CN Laser Printer Logo
215 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
