Question about Garden
I can't wind the string on a McCulloch 15RT
#1 Taper
  • 1040 Answers
SOURCE: How do you wind replacement line to the Poulan Pro
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Jim
  • 28 Answers
SOURCE: troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Posted on Aug 06, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
What size string does the 910 toro electric trimmer take
12' .050 trimmer line, like that shown at the link below
http://www.google.com/url?sa=t&source=productsearch&cd=1&ved=0CFkQgwgwAA&url=http%3A%2F%2Fwww.amazon.com%2FToro-88075-12-050-Trimmer-Line%2Fdp%2FB0000CBITQ&rct=j&q=910%20toro%20line&tbm=shop&ei=h2HNTd7aCunc0QGq_aDgDQ&usg=AFQjCNF826-xPNQy9XomBFrklrqkvIHGCQ&cad=rja&biw=1280&bih=630
May 13, 2011 | Toro& Electric String Trimmer
How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
Jul 01, 2010 | Black & Decker 14" Grass Hog Xp...
How to change the string
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Jim
Jun 23, 2009 | Toro Garden
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
