Question about Canon PIXMA MP150 All-In-One InkJet Printer
Cartridhge not printing properly
After refilling i have inserted black cartridge in my printer but it is not printing properly. The impression of the print is very light. please advise me what should I do to clean the printing head of the cartridge.
    Master:
  • 638 Answers
It must be not refilled properly.check the cartridge in another printer.from where have you refilled.or try another cartridge in your printer.there is always a problem after refilling
Posted on Aug 16, 2008
SOURCE:
I refilled the cartridge but it still willnot print
Please note that Lexmark does not recommend use of a refilled cartridge. Refilling a cartridge can affect print quality and may cause damage to the printer. For best results, use Lexmark supplies.
You may try to re-insert the cartridges and make sure they are seated properly or clean the cartridge nozzles. Manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Then, reinsert the cartridges in to the printer. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please replace your refilled cartridges with new genuine Lexmark supplies.
Sep 19, 2011 | Lexmark X2600 InkJet Printer
How to install the ink
Open the front cover on the printer. The print cartridges should slide on a conveyor belt from one far end of the print chamber to near the center. There should be one black ink cartridge and one color cartridge.
Remove the cartridges from the printer. This should simply involve grabbing and pulling the cartridges out. There may be a flap holding the cartridges in place that you need to flip up first. Or you may need to press down on the cartridges to spring them out of place.
Decide on replacing the cartridges with a brand new ones or refilling the existing cartridges. Refilling the cartridges can cost less money in the long-term and reduce waste, while new cartridges will guarantee to work and have the most ink up front.
Refill the cartridges with fresh ink in order to reuse them. With black cartridges, you need to drill or melt a hole in the cartridge lid, while you will remove the lid to find the color cartridge's holes. Inject the correct color ink with a plastic syringe bottle. Reseal the lid on a color cartridge after refilling.
Dispose of the cartridges properly after you purchase new ones. Take the old cartridges with you to whichever store you get the new ones from. Not only will this help you find the correct replacements, but the store may also take the old cartridges for recycling.
Insert the new or refilled cartridges into your printer. New cartridges likely have protective tape over the print head that you'll need to remove. Run a test print on the computer to make sure that the cartridges properly work
Check to see if the printer still reads the cartridges as being empty (if you are reusing a refilled one). This will be due to a chip in the cartridges that the printer reads for the ink level. It doesn't change just because you refilled the cartridges. You must purchase an electronic device that will reset the chip for you.
Chris Thrash
B52Computers
Jan 21, 2011 | Canon Office Equipment & Supplies
How do i change the ink cartridge on a canon mp560 printer
Chris Thrash
B52Computers
Jan 21, 2011 | Canon MP560 All-In-One InkJet Printer
HAD BLACK INK CARTRIDGE REFILLED AND REPLACED , PUT IT BACK INTO HP7550 PRINTER, NOW IT DOES NOT PRINT AT ALL DID NOT PRINT A CALIBARATION PAGE
You usually have to install a DIFFERENT cartridge at first to fool the printer into thinking you changed the cartridge then swap to the refilled one... Their feeble attempt at making sure you don't refill and use the same one.
Oct 27, 2009 | HP PhotoSmart 7550 InkJet Printer
Print cartridges missing or not detected
Are they new cartridges?
If so, have you removed the clear plastic protection strips from the cartridge heads?
Sep 15, 2009 | HP Photosmart C4280 Aio Printer
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Swap black inks with Epson 9800
By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
www.colorbyte.com
I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
Mar 20, 2008 | Epson Stylus Pro 9800 InkJet Printer
Black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
Oct 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
73 people viewed this question
Clive
Clive
old marine
old marine
Ekse
