Question about Miele CVA615 Espresso Machine
My Miele 615 Coffee System continually displays "Fill Watertank" Fault when the tank is full, which prevents it from operating. Sometimes I can get it to go after going through series movements of taking the tank in or out, or the waste unit. I'm assuming it's a sensor that's bad.
The water tank has a black float that runs inside a "tunel" in the watertank, and that is somehow conected to the water level sensor; if you are holding the tank and looking down into it, look at the corners to find the little tunel in which this black float runs.
In my unit, this "float" gets stuck down low sometimes (I have very hard sandy water) and I get the same problem, especially during descale. It is usually fixed by opening up the tunel (it has a small tab lid) and cleaning really well with a soft brush. hope this helps!
Posted on Jun 20, 2011
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
Screen says 'Fill Watertank' when watertank is clearly full.
Sounds like the sensor that detects system water levels has failed.
If you can see it inside try cleaning it or ask Miele for some advice via their website
Apr 14, 2010 | Miele CVA615 Espresso Machine
Miele coffee system cva 615. Message: Water System fault. What can I do?
More then likely there is nothing wrong with the water seal but simply the tank was not placed properly over the seal and water was bypassed to the reservoir. If a significant amount of water sits in the reservoir the "Water System Fault" trouble will appear and stop operation. The easiest way to remove the water from the reservoir is with an inexpensive ($5) siphon tool available at any auto parts store. Once the water has been removed and you can operate the machine and it goes through the "Warming" sequence you will receive a "Air in water System" alert. Follow the simple directions in the manual to correct this trouble and your system is back to normal. I have heard people have been charged by technicians up to $600 to fix this trouble and told the seal had to be replaced. Just take care when placing a full water tank back into place and enjoy : )
Mar 07, 2010 | Miele Coffee System
Miele cva615 says fill watertank but its full how do I reset
There's a little magnetic float in the tank - it may be stuck or missing.
Feb 25, 2010 | Miele CVA615 Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Miele coffee system "Fill Watertank" issue
there is a liltle floating black thing at the back of the container, this works as a magnet switch. see if it is there or is stuck and doesnt raise with the water level.
Apr 13, 2009 | Miele Coffee System
I get the message Fill Watertank on my Miele CVA 620 Built in automatic coffee maker but the water tank is full. I think there might be a problem with the float switch but am unsure how you correct it
The float switch is a proximity sensor. There's a float in the tank that triggers the notification when it leaves the proximity of the sensor, located on the right side of the tank cavity. Try cleaning everything and make sure the float is moving freely in the tank.
Nov 25, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
139 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
