Question about Kenwood KCA-RC900MR Remote Control
The face plate on my Kenwood kca-rc900mr started to crack and pieces are falling off. Do they offer a faceplate to replace it or do I have to buy a new remote. The remote I have is only 7 years old.
3 Suggested Answers
  • 157 Answers
SOURCE: The volume up on our Kenwood KCA-RC900MR does not operate.
Try it with a universal remote if you have one or know someone with one.
Posted on Jun 16, 2009
gopakumarg43
  • 75178 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on May 03, 2015
My kenwood kdv 2339 faceplate stole last june. where can i find or buy same faceplate? thanks!
Unfortunately the same MODEL FACE PLATE is needed to work the set. So this can be sourced only from Kenwood as a spare as most of the dealers will not have a spare one. You can request to the service support of Kenwood near to your place for ordering the front panel.
The other option is to try for a second hand from a scrapped set most of which has a damaged main unit.
Jul 22, 2011 | Kenwood Car Audio & Video
Kenwood KRC 535 - Faceplate stops halfway when turning off unit. When unit on it will play music, but nothing lights up so you don't know what you're listening to. Also cannot change station. ...
There is a fine ribbon cable that links both the main unit and the face plate. Due to the constant movement of opening and closing some of the conductive tracks develop cracks. That is the reason why when it closes half way it looses contact and the motor stops turning. The display illumination track must have completely broken.
You will need professional help to replace it because its a little complicated to access this ribbon cable.Will cost you about 15$ plus labor.
Jul 14, 2011 | Kenwood KRC 535 Cassette Player
Faceplate is not displaying anything.Knobs are ligthing up but no display.What could be wrong?
You have not mentioned how old it is. Some older models of Pioneer and Kenwood use a flat ribbon cable between the face plate and the head unit. Due to the constant opening and closing of the faceplate the ribbon develops a crack and you loose display or some times some functions.Will need professional help to replace the above.
Mar 08, 2011 | Kenwood KDC-MP635 CD Player
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
Jun 16, 2009 | Kenwood KCA-RC900MR Remote Control
Face wont open
if you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
Face plate on KDC-MP528 kenwood deck wont open
if you have checked all of your wiring and fuses and already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Kenwood KCA-RC900MR Remote Control Logo
50 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
