Split unit aicon fujiaire appear e3 message - Heating & Cooling
I have a Fujiaire split unit(wall type). I have this problem quite frequently, an error code E04 display, Try to look at the operating manual, it does not specify the problem, I check the compressor motor winding, the amount of F22 charge and clean the outdoor and indoor unit. Wonder why put an Error code when there is nothing on the troubleshooting list. But whenever the authorize repair man come for servicing, he could not tell me. Does anyone has a solution?????
Posted on Dec 16, 2011
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
How do i dismantle the aicon unit
First thing u have do is pumpdown the unit close discharge line wait for few seconds check the suction line when coolness of suction line goes also close the suction valve and then dissconect all power supply then u can remove copper tube and easily dismantle a/c unit.
Oct 05, 2014 | Mitsubishi MSZ-A24NA Split System Air...
Received u8 alarm display,aircond type fujiaire
Here's a link to fujiaire's contact page: http://www.fujiaire.com.my/contact.html
I'm sure they'll be able to tell you; or else contact your dealer- installer
Jul 11, 2014 | Cars & Trucks
Fault code f6 fujiaire model fbsv2452rk,
HI ALL, HERE JUST WANT TO ASK ABOUT ERROR E3?
Apr 22, 2013 | Heating & Cooling
I have a Fujiaire split unit( wall type). The problem i have now is when i run the unit, it show a thick icing on the discharge side till to the indoor unit and also the air coming out from the unot os not...
System has lost some of the refrigerant charge. This means the system has a refrigerant leak.
Have a reputable heating and air contraxctor find and repair the leak, recharge the system and it should run perfectly.
Sep 04, 2011 | Fujitsu Heating & Cooling
My voltas split AC did not work and shows E3 in the display. i try to change mode but no use
power indoor and outdoor units down record all info in and out make m# s# froward to me ..also need history of unit when installed past problems.
Jul 03, 2011 | Heating & Cooling
I have a conia split system and e3 has shown up on inside unit
Indoor unit air sensor defective. Replace it. Thanks.
Feb 04, 2011 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
809 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
