Question about AOC 177S-1 Monitor
Turn on after 5 second trif off... - AOC 177S-1 Monitor
    Guru:
  • 767 Answers
Can you see the desktop faintly? If so then it may be that your backlighting has blown. See my tip here for more details: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
Posted on May 26, 2011
Fuel being being pumped out off r/h air filter for a few seconds, does it when trying to start as well!
it's normal for it to run for 5-10 seconds if you turn the key but do not start the car it will shut off.
Apr 15, 2013 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
Changed a bad battery in my 2005z71. with new battery in @ start up the AC only blows hot air. was working just before battery change. Fuse check out fine. What do I need to look for?
Start the truck,and turn ac on,cold setting and all,let it run for 20 seconds,and turn ac off,then wait 5 seconds turn truck off,,wait 5 seconds,and then start truck,wait about 5 seconds,and turn ac on,see if this helps.
Jul 20, 2010 | 2005 Chevrolet Silverado
Car is revving when clutch is in or idle, idle learn procedure
IDLE LEARN PROCEDURE Whenever the battery cables, the engine control module
(ECM), or the ECM fuse is disconnected or replaced, the
following idle learn procedure must be performed:
1. Turn the ignition ON for 5 seconds.
2. Turn the ignition OFF for 5 seconds.
3. Turn the ignition ON for 5 seconds.
4. Start the engine in park/neutral.
5. Allow the engine to run until the engine coolant is
above 185° F (85°C ).
6. Turn the A/C ON for 10 seconds, if equipped.
7. Turn the A/C OFF for 10 seconds, if equipped.
8. If the vehicle is equipped with an automatic transaxle,
apply the parking brake. While pressing the
brake pedal, place the transaxle in D (drive).
9. Turn the A/C ON for 10 seconds, if equipped.
10. Turn the A/C OFF for 10 seconds, if equipped.
11. Turn the ignition OFF. The idle learn procedure is
complete
Jan 25, 2010 | 2001 Daewoo Nubira
When security light flashing,will not allow car to start,why??
Because you have to let the system relearn the keys for some reason. Its a pain in the nack but do this:
Turn key in the ignition to ON
Wait for 10 minutes.
Turn it OFF
wait for 5 seconds.
Turn it OFF
wait for 5 seconds.
Turn it OFF
wait for 5 seconds.
Start the car as you would normally.
Good luck.
Jul 11, 2009 | 1999 Oldsmobile Alero
Refridgerator acting erratic
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
May 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Car wont idle
idle stepper motor(IAC) controls idle speed it is located on throttle body
f33d4ad.jpg IDLE LEARN PROCEDURE
Whenever the battery cables, the electronic control
module (ECM), or the ECM fuse is disconnected or replaced,
the following idle learn procedure must be performed:
4. Start the engine in P/N (park/neutral).
5. Allow the engine run until the engine coolant is
above 85_C (185_F).
6. Turn the air conditioning (A/C) ON for 10 seconds, if
equipped.
brake pedal, place the transaxle in drive (D).
complete.
May 07, 2009 | 2000 Daewoo Lanos
AOC 177S-1 Monitor Logo
46 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
