Question about Bernina Virtuosa 150
Problem with Bernina 153 motor
Hi Rick, I have a 153 that has been working perfectly but I put a filled bobbin on the thread spindle, to keep it out of the way, and while sewing away the end thread started wrapping around the turn wheel of the machine. All of a sudden I heard a bang, and stopped to look and found my bobbin all wound up around the spindly very tightly, and my motor wheel wouldn't move. I think the thread slipped into the small crack and jammed what little free space was there. I need to know how to actually get the cover off of the machine so I can look at the wheel hardware. I can't seem to figure out how to even get the cover off. I feel dumb but then read your earlier blog and I felt better after hearing it is hard to remove.
Thank you in advance. Deborah
  • 202 Answers
The problem with removing the covers is all the wire connections you have to unplug after taking the cover screws out and prying off the balance knob on the side. If you are not grounded you can send a static charge through the circiut boards thus eliminating them from functioning ever again. We wear a wrist strap with a grounding wire. Its possible you may have put the bobbin in the case wrong and it was turning the wrong way. The right way is clockwise. I really have to suggest it be looked at by a tech. Sorry.
Posted on Nov 05, 2008
Bobbin thread tangling into knots on my Bernina QE 153
Its possible, refer to your machine manual to adjust the tension. You might need to change your needle to fit the thread you are using.
Feb 01, 2013 | Bernina Virtuosa 150
I have a Bernina 153 QE Virtuosa. The bobbin carriage is noisy. When I notice that it is suddenly sounding smoother, I can be sure it has run out of bobbin thread. I have taken it in to my dealer for...
The previous answer is incorrect. The bobbin should turn clockwise in the bobbin case, but then the thread doubles back through the bobbin case tension slot so the end of the thread would be pulling counter clockwise. Are you using genuine Bernina bobbins? Sometimes, generic bobbins do not work as well.
Are you applying a drop of oil to the shuttle/hook area every 8 hours of sewing time? Lack of oil makes my machine noisier. When I notice the sound has changed, I know it's time it needs some TLC.
If you are still having problems with the Bernina technician, try to find another dealer.
Dec 15, 2017 | Sewing Machines
I lost the book and can't figure out how to thread the bobbin... it was a gift from my mom and was completely ready to go when she gave it to me...
Hi, after your bobbin is wound insert it into the bobbincase. When you pull the thread the bobbin should turn clockwise. Then slip the thread through the notch and up under the spring. There is a small screw on this spring that adjusts the thread tension on the bobbincase in case you have to adjust it later.
Hope this helped.
Rick
Bernina tech
Dec 06, 2009 | Bernina Activa 130
Have the artista 180 and the thread keeps
Hi, possibly you have put the bobbin in upside down. Try flipping it over in the bobbincase and see what happens. It should turn clockwise when looking at the bobbin and pulling the thread.Check that your upper tension is not too loose. Check that it is threaded correctly.
Hope this helps.
Rick
Oct 07, 2009 | Bernina Artista 180
I cannot get a perfect stitch on my Bernina 1260. Some of the bobbin thread shows on top no matter what I try. I have tried different needles, threads, tension settings (even adjusting bobbin tension). It...
Possibly its the check spring that takes up the slack in the thread as the needle pierces the fabric. slowly lower the needle through the fabric and watch if there is slack in the thread just above the fabric. If there is then this check spring needs to be adjusted. I hate to say this and its not just because I am a Bernina tech but its time for it to be serviced. many things might be the culprit. The distance between the hook and needle could be off for one more reason. Or something dirty or fluff under the spring the thread goes under on the bobbincase. Either a servicing or use the same color bobbin thread beneith is in order. Wish I could help more but you have tried a lot so I ruled those out such as tighter bobbin tension or looser upper tension or the combination of both.
Good luck
Rick Engel
Oct 05, 2009 | Bernina Sewing Machines
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
Machine not working after bobbin installation
Hi, it may be possible that you put the bobbin in the case upside down and its turning the wrong way. Flip it over and try it. When looking at the bobbin in the case from the back and you pull the thread, it should turn clockwise.
Hope this helped as anything else may take a tech to diagnose.
Rick
Mar 21, 2009 | Bernina Virtuosa 150
Threading the bobbin
It could also be the tension of the thread while you are threading the needle through the upper system. Keep a slight tension on that thread while doing it. Otherwise, make sure that the bobbin thread is 'coming' from the right position on the spindle.
Nov 08, 2008 | Bernina Virtuosa 160
White 2037 Bobbin Filling
turn your thread 3 turns to the right, clockwise,
then pass theend of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Jun 14, 2008 | Sewing Machines
Sewing Machines Logo
177 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
