Question about Emerson MS3100 3-Disc CD Changer
I jusst received an Emerson MS3111. Everything seems to be working well, except I have a lot of "noise" when playing the CD...everything from "static" to a popping. Is that the receiver, the speakers, or my CDs?
    Brigadier General:
  • 8,546 Answers
Well, if it's only the CD doing it...
If other sources make the sounds, look at something common like the receiver.
Speakers that aren't physically damaged or overdriven don't 'create' sounds that are not present in the amplified signal.
Posted on May 26, 2011
Cd player says no rdy
Everything was working fine it reading the CDs playing music then one of the CDs jammed after that everything worked except the CDs were not spinning and it now says no rdy wtf can be wrong
Jan 19, 2013 | Emerson MS9700 CD Shelf System
Rear speakers on vsx1122 not playing, they tested okay
Manually change your surround settings for your satellite box input. Your box may not be putting out a signal that the receiver auto-detects as a surround sound signal, thus it just plays in stereo.
Dec 26, 2012 | Pioneer VSX-1122-K Receiver
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Jan 08, 2008 | Sony CDX-S2010 CD Player
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Oct 16, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
My Emerson NR305TT will not produce sound. Turn table works, CD Player works, FM Tuner Works, everything works except no sound comes from the unit. The on switch and volume seem to work as I hear a faint...
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Jun 19, 2006 | Emerson NR305TT CD Shelf System
Emerson MS3100 3-Disc CD Changer Logo
90 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
