Question about Kodak i40 Path-Through Scanner
Papers appear not to grip and go through scanner
  • 3 Answers
You may want to try cleaning the scanner or changing the seperation pad http://scannerstore.kodak.com/ has the part you need.
Posted on Sep 15, 2011
Scanner has stopped pulling paper through. Tried cleaning and still doesn't work. What next?
Verify that the intake roller is turning, that there is no obstruction keeping the paper from reaching it, and that the rubber on the roller is not too hardened to grip the paper.
Jul 03, 2015 | NEAT Desk Desktop Scanner and Digital...
My Brother MFC 210C Printer, Copier, Scanner isn't feeding the paper.How do I fix this?
Use a water dampened cloth to clean the pickup roller. They get residue on them over time that causes them to not grip the surface of the paper when feeding.
Feb 06, 2015 | Brother Office Equipment & Supplies
Hey,i have Canon iR1530 got paper jammed.how to release the paper?
slide the scanner/DADF unit to left side,
there is slide handle on the left side above paper exit place.
pull like as door hadle car. while sliding the scanner to the left too.
then open up the cover which below the scanner.
pull out the drum unit which the black color, there is a iron grip.
and you'll see the paper. pull out carefully.
put back the drum unit. and back it all to position.
good luck
May 16, 2011 | Canon imageRUNNER 5000 Copier
For some reason our printer is slipping while printing
what tends to happen is that the rubber feed rollers go shiny so cant grip the paper properly, sometimes you can get a maintenance kit which replaces the parts that wear, but a simple trick which sometimes helps is to get something like an emery board (ladies use them to file their nails) and gentle rough up the surface of these rollers, dont be too rough, otherwise you will make the rollers too small to grip the paper, almost no pressure at all, just dull up the surface.
Hope this works/helps
May 07, 2011 | Computers & Internet
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
    Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Scanner pulls through more than one sheet at a time, continually, but not all the time, and often jams for no apparent reason.
    Clean the rubber rollers with a damp, but well wrung, cloth. No solvents please!. This will remove all the paper dust and give necessary grip to the rollers. If they are worn out you need to replace them.
    S. Mohan
    Oct 22, 2009 | Panasonic KV S2026C Path-Through Scanner
    Scanner will not load from top feeder. Error says paper jam but no paper is jammed into the feeder.
    the rollers may be broken, this would give the appearance of the paper jam to the printer
    sorry not sure how to fix this one
    Oct 09, 2009 | Visioneer 9450 Flatbed Scanner
    E4 comes up on panel saying clear paper jam
    With out knowing which stylus you have there error either refers to a paper jam or ink cartridge error. If it takes the beging of the paper but then stops it could be a matter of worn rollers that are not able to grip and move the whole page.
    Nov 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Lexmark scanner/printer x5250
    Yup rubber feed rollers can be replaced of even try just cleaning rubber with slightly damp cloth to remove paper dust that causes them to slip and not grip and feed paper as they should
    Oct 19, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
    Kodak i40 Path-Through Scanner Logo
    80 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
