Question about Frigidaire FAC127S1A Air Conditioner
I have a fac127s1a frigidaire air conditioner and when i turned it on it is making a loud grinding hum. i really don't know how to describe the sound. it is giving out cool air.
2 Suggested Answers
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
How do I clean the condensation drain on my Fridgidaire fac127s1a?
I understand you want to know how to clean the condensation drain on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, and beginning to leak from the front. The drain hole is located beneath the compressor. You would have to get underneath that to clean the drain. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire fac127s1a is really loud - 70db+ - any fix available?
You might be able to find a sound insulating blanket that wraps around compressor. Check with a Carrier or York dealer. Most brands use the same compressors so you might be able to score one.
Jul 02, 2014 | Intertherm P3RC-042K Air Conditioner
Frigidaire Air Conditioners make alot of noise when running
Hi James - Thank you for your question! I am happy to assist you. I understand you stated it sounds like a bad bearing, however may you please describe or me more specific in the particular noise the air conditioner is making? Does the noise occurred at all times? With this information I can better address the issue at hand and provide you the most accurate information. Thank you and I look forward to your response.
Jul 18, 2013 | Frigidaire Heating & Cooling
Need wiring digram
Some units the cord is actually detachable, if you don't think this one is, contact your manufacturer to see if they offer a replacement cord that you can purchase. Some do, some don't.
Sep 06, 2012 | Frigidaire FAC127S1A Air Conditioner
Frigidaire FAC127S1A Air Condition power cord plug will not reset. The breaker built into the power cable of our electric AC will not rest causing the unit to be inoperable. The manual says to get a...
No, Jerry, I don't think Lowe's will carry that. They carry a ton of things, but that's not one of them. Contact a local Frigidaire dealer. As they usually have parts dept. Or you can go to the following Frigidaire link and find a parts distributor in your area.http://www.frigidaire.com/partsdistributorlocator
I hope this has helped you. Thanks for choosing FixYa.
Jul 26, 2011 | Heating & Cooling
Need to know if the vent should be open or closed or fresh air setting while running ?
personal choice, open allows unit to exahust stale air, closed gives better efficiancy (minimal)
Jul 22, 2011 | Frigidaire FAC127S1A Air Conditioner
There is dirt behind the air directional louvers inside the air conditioner unit. How can iot be cleaned? The crevice tool of a vaccuum won't fit inside, besides the "dirt" seems to be...
Download manual from here: http://www.searspartsdirect.com/partsdirect/user-manuals/FAC127P1A1-Frigidaire-Parts-Room-air-conditioner-Parts-manual
Jul 20, 2011 | Frigidaire FAC127S1A Air Conditioner
Yes, we have a fridgidaire FAC127S1A Model and we installed it today and are having trouble with it leaking water once it runs for a while. (The hole on the under side of the A/C.) Is this normal or is it...
If the water is leaking to the outside, that is normal. Especially if, the humidity is high outside.
If it's leaking to the inside. No, that's not normal and is due to improper installation. The rear of the unit should tilt down about 1/4" , to allow the water to drain outside via the drain pan hole.
To help you further, I have included a link to the Owner's Manual for your FAC127S1A model air conditioner. You can download and print it for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020213A0310en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | Frigidaire FAC127S1A Air Conditioner
Frigidaire FAC127S1A Air Conditioner Logo
46 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
