Question about Canon imageRUNNER C3220 Color Copier
I can not scan from my color image runner c3220 to my computer. Its on a network, and I installed the network ScangearTwain Driver. It see the scanner but does not allow me to scan. I can print to the machine but can't scan. I need some assistance
    Sergeant:
  • 372 Answers
Its a titywity prob sir. i have also faced it .it sometimes work some times doesnt. if u have installed the scan gear then u have u use a scanner software life adobe etc to access the scanner through it. u can also use word,photoshop,corel etc to access it
Posted on May 26, 2011
I have a Image Runner C3200 and it is tinting the paper black when making copies
- clean the laser units glass with the special cleaning tool provided with the copier
- check and clean the image transfer belt blade and the recycle mechanism
- check if the tinting is on the imaging unit , if yes change unit if not chevk above
Jul 27, 2012 | Canon imageRUNNER C3220 Color Copier
Have Cannon image runner iR 3300. It is networked to our computer. It prints some pdf files and some of them it doesn't print.
This is probably a Adobe problem, but i might know how to fix it. When selecting the printer you want to use in Adobe reader, press the "Advanced" button at the bottom of the window. Press the "Print as picture" box. This should probably fix it.
Nov 12, 2010 | Canon imageRUNNER C3220 Color Copier
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
How to print enevelopes from cannon image runner C3220
You simply run them through the bypass tray, about 10-15 at a time. There is no fast way to do it.
Jul 09, 2009 | Canon imageRUNNER C3220 Color Copier
How can i print envelopes from my cannon image runner C3220
Look on pages 2-42 thru 2-53 of the Reference Guide for the proper proceedure.
How to align an image runner C3200
The colour alignment is carried out automatically. Run auto gamma adjust. If this does not resolve anything, some part is at fault. Typical faulty item would be slipping transfer belt.
Mar 31, 2009 | Canon imageRUNNER C3220 Color Copier
Unable to set up scan feature.
First question is do you have universal send on the copier. If you have a Send tab on the touch screen you have it, if you only have a scan tab you do not.
With the send tab you can set the device up to scan, create a file and send it to a network destination. With the scan button you have to install the color network scan gear program on your computer.
http://downloads.canon.com/cpr/software/imagerunner/CNSG230.exe
This software is just a twain driver that interfaces with the copier through the network. It does not give you any software to drive the scanner, it only gives you a choice for the copier in your list of scanners. You have to use some other program (i.e. Acrobat standard or MS document imaging) to drive. After you install it open it up, let it discover the machine on the netowrk and close it. The interface only points to the device on the wore, it is not directly used for scanning.
If you have a send button I would recommend for your situation that you scan to a shared folder on your desktop. First you create the shared folder, and make sure you can see it from another PC on the network. If your other PC's can't see it the copier won't either. Create a user on the computer with the shared folder for the copier to use. Set that users password to never expire.
Press the additional functions hard button
Press the touch screen button for address book
Add an address to address book # 1
The type of address will be SMB
Register a name for the address (Scan to PC is fine)
there should be a browse button on the screen, press it
Use the up and down arrow to browse up and down the tree
when you see your network browse from the domain to the PC you are scanning to
When you try to expand the PC you will have to enter in the user and password you created for scanning
point to the shared folder you will use
OK your way back out to the user screens
Have fun scanning
Aug 20, 2008 | Canon imageRUNNER C3220 Color Copier
Immage Runner 3300 and laptops
First of all you have to have the scanning option installed in machine. Then from each pc to scan you have to install a software called scangear.
Jul 29, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
It doesn't print some pdf files from our computer
you can try to use the postscript driver, it should proccess it better. If you need to use pcl driver change the driver setup... under the properites of the driver click port tab... click config port....click lpr and in the Queue name type...print
this should help if not you may need the service tech. to upgrade software rp
Mar 19, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
254 people viewed this question
old marine
old marine
