Question about ASUS Eee PC 1000H Laptop
My 1005HAB keyboar9d has9 started generating the number 9 at random times...as you9 can see! this9 is a hu9ge problem. HELP!!
    Problem Solver:
  • 14 Answers
The keyboard is broken and the 9 key got stuck, try lifting it gently with a pencil's point, if it get stuck again after pressing it, then you may need to replace the keyboard wich is cheap, look for it on ebay. To change the keyboard look for the fasteners above the top keyboard row they look like tiny metallic wires press them with a clockwork screwdriver and the keyboard should release, then free the ribbon cable losening the plastic fastener. Put your new keyboard ribbon cable and tight the fastener, sleep the keyboard in place... presto
Posted on Jul 02, 2011
Stops generating and just idles
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Mar 28, 2017 | Honda EU6500iS Inverter Generator
My laptop 1005hab notebook is stuck on window xp will not go any farther
Unplug AC, remove battery, leave out for now, plug in, boot normally. If that fails, unplug ,plug in, reboot, IMMEDIATEDLY start tapping the F-9 or system restore/recovery key, restore to a date before this occured or do a system recovery to return to factory settings.
Nov 12, 2012 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Use RAN# button to gnerate random numbers
The RAN# button generates a random number between 0 and 1.If you want to flip a coin, see whether the generated random number is less than 0.5. Alternatively, multiply by 2 and see whether the integer portion is 0 or 1.If you want to flip a die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a number in the range 1 through 6. A similar method will allow you to generate random numbers in any range.
Apr 16, 2012 | Casio FX-55 Calculator
How do I use the random number generator to generate numbers between 1-100 or 1-10
The random number generator generates a number between 0 and one. To get a random number between 1 and 100, multiply the generated number by 100, add 1, and discard the fractional portion. To generate a random number between 1 and 10, multiply the generated number by 10, add 1, and discard the fractional portion.
Mar 24, 2011 | Casio FX83ES Scientific Calculator
How do I generate a random number that is greater than 1 on a casio fx-300MS
The random number function always generates a number between zero and one. You can convert this to a random number in any range by a suitable combination of multiplications and additions. For example, if you want a random number between zero and ten, multiply the generated random number by 10. If you want a random number between one and ten, multiply the generated random number by 9 and then add 1.
If you want to simulate the roll of a six-sided die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a 1, 2, 3, 4, 5, or 6 with more-or-less equal probability.
Mar 10, 2011 | Casio FX-300MS Calculator
Lost instructions for photocell Type:ET321
Here is how it works. The push button repeats itself in following sequence (must plug in).
F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off.
1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings.
A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (on from dust, but off randomly) time shows no pattern to outsiders.
d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion.
1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Dec 08, 2010 | Impact First Alert Outdoor Digital...
Instruction for first alert et321 timer
F: timer is off.
Dec 13, 2009 | First Alert Hardware & Accessories
How to use the random number generator on the calculator.
To access the Random number generator, press [MENU], Use arrows to select [RUN] and press [EXE].
In [RUN] press [OPTN][F6:->] to pan to the right then press [F3:PROB] then [F4:RAND#]. The command echoes on the screen.
  1. Now if you press [EXE] a number between 0 and 1 is generated.
  2. Each time you press [EXE] a new number is generated.
Although it is not documented, I found out that if you enter RAND#(n) where n is an integer, it generates a number between (0 and n)
Hope it helps.
Nov 07, 2009 | Casio FX-9750GPlus Calculator
Generating random numbers
Turn calculator ON, press MENU if you see no icons. Use arrow key to highlight the RUN application. Press OPTN, press F6 to pan right. Press F3: Prob, then F4:Ran# then EXE to execute.
Each time you press EXE a new random number is generated. You might want to fix the number of decimal digits to less than the 10 digits displayed by default.
By default number generated are between 0 and 1. If you want numbers between 0 and 100 you enter Ran#(100).
Hope it helps.
Oct 20, 2009 | Casio CFX 9850GB Plus Calculator
Statistics
Random number generators on computers are not really random. They need to be "seeded". If you seed the random number generator with the same seed each time you will generate the same list of numbers. A common technique in computer programming is to seed the random number generator with a value like the number of seconds that has occurred since midnight. This gives you the illusion of real random numbers.
Look up the word "Seed" in your calculator documentation and it will most likely tell you how this is accomplished on the TI calculators.
Nov 20, 2007 | Texas Instruments TI-83 Plus Calculator
ASUS Eee PC 1000H Laptop Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
