Question about HP Color LaserJet 2600n Printer
Refurbished Magenta cartridge, others okay, receiving 10.0002 supply error. Can I fix this without going to the much more expensive HP toner cartridges?
    Scholar:
  • 118 Answers
The error is caused by the small micro chip on the magenta toner cartridge. You may be able to purchase a chip from a toner cartridge remanufacturer but I would return the cartridge to where you bought it and tell them it is faulty and have it replaced.
Otherwise purchase another toner cartridge.
Posted on May 26, 2011
Testimonial: "Other things I had looked at led me to believe that the cartridge was faulty. Will contact the seller. Thanks!"
HP CP1515n Toner tray stuck on right side
you should check transfer belt or fuser unit.
Aug 24, 2016 | HP LaserJet CP1515n Printer
Toner yellow, magenta and black lights are flashing. cannot put in magenta toner as the "arrow" positions are not at the right places.
This sounds like the carousel in the printer has gone out of alignment. This is usually caused by using old generic toner cartridges. ( the roller on the toner cartridge seizes and causes carousel to go out of alignment. )
There are other easy fix instructions on here to realign the carousel.
Jul 17, 2011 | HP LaserJet 2550L Printer
I replaced the magenta cartridge with a cartridge from cartridge world. I keep getting an error message that says "10.10.02 supply memory error." What do a i do. I already took all the cartridges out and...
This is usually caused by a third party toner and not an hp toner cartridge. My suggestion would be to see if you can get an oem hp toner cartridge (magenta) and see if the error goes away. If the error goes away then you know its the toner cartridge. This happens because all the manufactures put a chip into the cartridge that make it so you have to kinda use there toner. When third partys manufacture cartridges sometimes there chip they use is not compatible with your printer. Another way to test this would be to put your old one back in. You will still get toner empty but at least the 10.10.02 should go away.
I hope this helps please let me know how it works out. thanks
Steven.
Apr 21, 2010 | HP LaserJet 3600n Printer
HP Color LaserJet 8500dn - Error Code 54.2 Carousel Cycle Power is preventing me from printing. I recently changed the magenta toner and it clicked in normally, but the error code came up. The manual says...
Even thought the cartridge clicked in normally, there is a problem with it. If you still have the old one, put it back in, if the error clears, you know the new toner is no good. If the flap doesn't lift or is binding it will stop the carousel from spinning, a 54.00.02 is a cyan toner error. If you have another toner you can try that also. I know they aren't cheap, but a lot of refurbished toners can do this out of the box.
Apr 09, 2010 | HP LaserJet 8500 Color Printer
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Refurbished printer, black is fainter than I need
press the check mark, scroll down to print quality.
you can adjust the setting from 1 to 5 and make sure econo-mode is off.
Mar 05, 2009 | HP LaserJet 4250dtn Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
REPLACE SUPPLIES
Make sure all cartridge are install and secured into place...(take all the cartridge out and back in ) close front door cover and it will go into cartridge calibration...If not, press the "menu" key and with the arrow go to print quality and confirm with the enter key. Go to calibration and confirm...
Let me know....
Mar 26, 2008 | HP LaserJet 2840 Printer
HP Color LaserJet 2600n Printer Logo
588 people viewed this question
Seeker5211
Seeker5211
