Question about Dell Vostro 1500 Notebook
Power problem in monitor
My DELL VOSTRO 1500 was running very well for 6 months. Now suddenly when i try to boot, it was not booting at all. When i press the power button , the power LED flash for some moments and then goes off, monitor remains black, if i press the power button continuiosly still the same problem. So i'm not able to start and boot the laptop at all.
  • afshin_sano Oct 07, 2008
    please give me some information of this problem when i press power bottom the led on for a little moment then off so some time 3 led on top behind the power bottom are on and after moment are off..somebody help me to solve this problem thanks for kind
  • 655 Answers
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Posted on Aug 16, 2008
Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
Mar 03, 2013 | Dell Vostro 1500 Notebook
I have my Dell Vostro 1500 asking for a bios password and i'm not sure if its set to boot from CD. Please help me on how to reset the system to default. I tried opening the computer and yet...
Some laptops can select an alternate boot device when you power up the laptop and then press F10 or F12.
When the laptop first boots up the display will show briefly the Function key you you need to press to go into the BIOS and/or the alternate boot device.
Jul 01, 2011 | Dell Vostro 1500 Notebook
I trying boot my dell vostro 1500 from sd-card on card I heave install Linux but when I run computer and pres F12 I don't see any sd-card to choose too run. Any wane heave idea why it doesn?t work? P.S....
You have to go into your PC and set the Boot options in the Bios setup to look there. Most Bios will only see USB drives abd hard drives,
On the dell to get into the setup you need to press F2 just after turning on the PC.
Sep 19, 2009 | Dell Vostro 1500 Notebook
Vostro doosen't boot from sd-csrd
Maybe if the computer is meant to be bootable from SD then the F12 screen would include the possibility. I think there is no way to boot from SD card.
Vostro 1500 does not boot
hi
dear it is not note book problem it is windows problem
insert boot cd of your desire windows repair it
thanks
Jul 19, 2009 | Dell Vostro 1500 Notebook
Dell vostro 1500 will not boot after installing norton systemworks
I would suggest to uninstall the norton systemworks. Because it may be incompatible or harmful for your computer. Try to run the computer in Safe Mode and see if you could perform a System Restore.
Hope it helps. Have a great day!
Jun 12, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1500 will not boot
NEEDS TO BE REINSTALLED SEE IF YOU CAN HIT F12 AND SEE IF YOU CAN GET THE BOOT MENU
Jun 06, 2009 | Dell Vostro 1500 Notebook
Operating system is missing is the message shown on my dell
Boot to the F12 menu, see if you can boot to the HDD diagnostics. If not, boot to the Dell Resource CD, run the HDD diagnostics from there. If Diags fail, replace the HDD. If they pass, boot to the Vista DVD, then run a repair of the operating system
Apr 07, 2009 | Dell Vostro 1500 Notebook
Dell vostro was placed on a wet counter. wont boot up
Change the AC adapter. It sounds like there is a dead short in the connector. If that doesn't work and it is still under warranty call dell support and they should be able to send you out a replacement. Just don't mention anything about water.
Mar 19, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1500 Notebook Logo
327 people viewed this question
Alun Cox
