My laptop has error boxes that come up and they say damaged hard drive clusters detected in another one it says ram memory usage is critically high and another says windows cant find hard disk space hard drive error
    Sergeant:
  • 223 Answers
Thank you for using FixYa
That sounds like a virus to me but it may just be a bad hard drive. I would look for your origional Operating system cd and see if you can get it to run off the cd instead of the hard drive. If you can get it to run at all you could run a diagnotics program on it but you would have to get to the internet first. There are numerous utillities that will check it out for you. Good news is that hard drives costs are way down and you can get one for 39 bucks or even an external one.
Here is a free one and there are others on CNET
http://download.cnet.com/windows/diagnostic-software/
I hope this was useful and please comment if this was helpful to you.
Posted on May 26, 2011
What does high CPU usage mean?
Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
Mar 06, 2015 | Computers & Internet
How do I reset factory settings on a compac cq60-615dx notebook
From your description, restoring the factory defaults will not fix the issue. you will likely need to replace the hard drive. However, to restore the factory settings, press f10 as the system is booting to bring up the recovery partition.
Jan 04, 2012 | Computers & Internet
Computer has crashed. Everything gone off desk top and program list. Everytime i start computer it opens data recovery window and goes through a scan, it says hard drive space less than technical...
hello, usualy in this cases the memory is the problem, any way if u already buyed 1GB ram ,wait until u get it and change it, let hope will resolve all problems, u can get an UBCD live cd and make some hdd and memory tests from it, and then if still dont work u can go to a specialst.
because will be a lose of money to go to a center now after u already got the RAM
this is my advice because is imposible to some one to resolv this whit out beeing infront of laptop
best regards
Sep 22, 2011 | Dell Inspiron 6400 Notebook
I think i have malmare. i can not see homepage. i get notices hard disc error, ram memory useage is critically high, ram memory failure, ram hard disc cluster detected, system detect problem ide/sata...
Hello.
Try System Restore.
Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Jun 24, 2011 | Acer Aspire 5520-5908 Notebook
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
What do I do when I get a window reads THE SYSTEM HAS DETECTED A PROBLEMWITH ONEE OR MORE INSTALLED IDE/ ALONG WITH CRITICAL ERROR ON THE THE HARD DISK
Sounds like either cluster problems with your hard drive or possible hardware sector damage, I would start by going to my computer right click on your C drive and choose properties then choose the tools tab the first tool on the list should be check disk. as soon as you run the check disk it will ask you do you want to schedule a check disk, select yes and reboot your computer. The windows check disk will start a very long process of checking your entire disk for errors or problems and attempt to fix them. In most cases that I have come across this issues signifies a hardware issue that may not fail for several months but finally will. I would replace the hard drive if the check disk does not work. most box stores will actually test the drive before they sell you the hard drive. Since you still have access to windows i would defiantly start backing up your important files and data while you still can.
hope this advice helps good luck and please reply if you have any questions thru this processes.
May 28, 2011 | Toshiba Computers & Internet
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
It comes up wiyh cricital error ram memory usage is cricitally high ram nemory faliure
The error means that there was not enough memory for an application to run. Close other memory intensive applications in order to have enough memory to let it run, or upgrade your RAM.
Mar 01, 2011 | Computers & Internet
My computer gives a damage hard disk cluster message. how can i secure may computer and what can i do.
In case of hard disk damage/ complete failure you may loose your data. Hence, it is highly recommended that you should immediately make backup of all your important/ critical data on CD/DVD or on external drive and contact HP Authorized Service Professional in your area for checkup of your laptop and repair/ replacement of hard disk.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | HP Pavilion dv6000z Notebook
I need help with a laptop problem please!!! It keeps telling me hard drive not found missing hard drive and then it says RAM memory usage is critically high RAM memory failure. how can i delete what is on...
Dear friend plase scan your computer for virus once contact your hardware vendor for service............or try updating your hardware drivers........hope this hepls u
Nov 28, 2010 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
