Question about HEWLETT-PACKARD 574508-001 - Original HP ProBook 4410s, 4411s, 4510s, 4515s, 4710s Series Laptop Motherboard (Sy...
Laptop don't start, power light on, harddisk light
    Sergeant:
  • 187 Answers
PLS REMOVE THE POWER CORD AND THE BATTERY FROM YOUR LAPTOP AND WAIT FOR 5 MINS THEN RE-INSERT THEM AND ON IT . SHOULD WORK
. PLS REPLY OR COMMENT.
Posted on May 26, 2011
Sir i have problem in hp charger or battery i don't know but when i charge my laptop at that time yellow light beside laptop which shows charging but after some time it is just simply plugged in a
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Oct 25, 2012 | HP Computers & Internet
I have an Acer Laptop with Windows Xp.... when i start my computer says |Be_$|Be_$| and i can't use it, what that mean?
LOL, I don't know what that mean!!! Maybe you should just get an operating system disk and reinstall it. You can do a Repair Install so that you don't lose any of your data.
Apr 19, 2012 | Acer Computers & Internet
My net acer zg5 AOA150 doesn.t go. He start only the light "on" but it doesn't go
you need a flash drive fat32 formatted,download the bios update from acer website.copy the flashit.exe & 3114.fd to flash driverename 3114fd to ZG5IA32.FD.insert ur flash drive to the right side usb port. turn on power while holding Fn and Esc key don not release the combination key until u count of 7 sec, when light is on push again the power button then release.it will blink in a minute and the light turn off, don't do anything until it restart. just relax it takes a minute.if you can't download the file e-mail me @ fccaole@yahoo.comgood luck guys! wait for 7 second to release
Jul 30, 2011 | Acer Aspire One AOA150-1784 Netbook
My pcg-fx220 vaio laptop has what looks like battery 1 flashing yellow light. I start it up but it doesn't get past the sony start up screen the little light just keeps blinking. It's plugged in so...
Take out the battery, plug it in turn it on, if the problem is the same unplug it. Turn it over and remove the access panel from the bottom. There you should find your RAM if you have two RAM modules installed remove both and replace them one at a time with the power off. So insert one and power on computer if the same result as before, remove it and insert the other RAM and power it on again. Also look to see if your CPU fan is spinning. If your fan only spins for 5 to 10 seconds and powers off one of three things are bad, either your CPU, GPU, or Motherboard are bad or damaged. It might turn on here or there if this happens it's probably your GPU. Hope this helps you.
Jun 28, 2011 | Computers & Internet
In dell 1525 laptop not booting and not flashing the light of harddisk
Please enter into BIOS and check whether the Harddisk is detecting or not. If not detecting, try to remove the hard disk and reinsert into laptop. check it.
If HDD is detecting, press F8 to enter to Safe mode after power on laptop. if safe mode is not working.. reinstall/repair the existing operating system with your OS cd.
Jun 28, 2011 | Dell Inspiron 1525 Notebook
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Dell Latitude D600 Boot problem
Weak battery, bad power supply adapter cable, and/or a dirty power switch can cause this problem.
Sep 19, 2009 | Computers & Internet
Some of the drivers are showing with yellow Icons and don`t work. The product is Toshiba laptop computer. some drivers and controllers don`t work and appear with yellow colors asking for instullations or...
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Go to :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Mar 08, 2009 | Toshiba 14.1" Satellite Notebook Computer...
Boot Failure
boot failure could be the harddisk is bad or the os in the harddisk is corrupt, try installing a new os, if failure harddisk is bad.
uzowuanya
uzowuanya@yahoo.ca
Oct 21, 2007 | Toshiba 4030CDT (P000271450) Motherboard
HEWLETT-PACKARD 574508-001 - Original HP ProBook 4410s, 4411s, 4510s, 4515s, 4710s Series Laptop Motherboard (Sy... Logo
808 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
