Question about HP Office Equipment & Supplies
I just changed the ink cartidges in my HP PSC 1510xi All-in-One Printer and now it won't print because the "Check Print Cartridge" light and "Color" light just keep flashing as if still empty.
    Master:
  • 638 Answers
Clean the brown dotted circuit of both the printer and your cartridge.it will work.or may be the cartridge is faulty,get it checked in some other printer of same model number.
Posted on Aug 16, 2008
My printer will not print. It feeds through the paper but no ink why?
is the cartridges are orginal or refilled?
if orginal clean the cartridge with sperit and try printing.
if it's refilled change the cartidge.
Dec 16, 2010 | HP PSC 1510 All-In-One InkJet Printer
"check print cartridge was flashing, so I changed the ink, but it still is flashing. Also, there is an "E" across from the copies button. I disconnected it from the computer and "check print cartridge...
hi, is it hp ink cartridges? did you refill cartridge or replace?
press cancel button, then on/resume. if no change. make sure all tape, paper is removed from ink cartidge connectors and there is no dirt, smudges or adhesive or anything else that may interfere with the connection. reinstall cartridges. if still no change, power off, then disconnect power. wait about 5 mins. reconnect and power on. this should reset the printer.
Apr 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have a hp psc 2410 .the black is printing beautifully but the colour it printing doubled or blurry. changed colour cartridge and still the same. help please
Your inkjet nozzles may be clogged with old dried ink. Try removing your color cartridge and looking at the area on your print carraige where the inkjet cartridge mates up with the carriage. Use a Q-tip and warm distilled water to gently swab this area until all the old ink is dissolved and it wipes clean. You may need several Q-tips for this. Allow to air dry and reintall your print cartidge. Your printer should go into an automatic cleaning cycle. You may also need to gently clean the area on the cartidge itself using the Q-tip method. Good luck.
Feb 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check www.hp.com. Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
Print cartridge in right stall not supported
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
Sep 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
Ink cartridge stalled
hmmm..did you clean and recalibrate your print heads after replacement?
also, you might want a fresh set of print drivers. get em here
Mar 10, 2008 | HP PSC 1350v All-In-One InkJet Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
240 people viewed this question
Ben Johnson
