Question about Frigidaire FAH106R1T Thru-Wall/Window Air Conditioner
Frigidaire window/wall AC 3 yrs old large unit - fan sounds like a jet engine. Cools great, fan great...just louder this year. Took out and cleaned and WD-40'd things already. Advice?
RepairUSA
  • 50 Answers
SOURCE: Window AC takes spells on cooling?
One thing to check is to make sure the evaporator and condenser coils are clean. Any dirt here will short ccle the compressor.
Posted on Aug 25, 2007
  • 1894 Answers
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
please leave the unit unplugged from the main power for few hours and check if it works
Posted on Jun 29, 2008
  • 958 Answers
SOURCE: fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
  • 2976 Answers
SOURCE: my frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
Posted on May 25, 2009
SOURCE: frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Posted on Apr 24, 2010
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
Ac is not blowing as hard and it was but is still cold?
Have you checked the current supply going to the A/C? A simple voltmeter will work or you can try a KILL-A-WATT available online or from many local retailers. You should be looking for approximately 120VAC @60 Hz. 5 years does not seem very long but given the way manufacturer's are making A/Cs these days I suppose the fan motor or motor bearings could be going bad. I don't know the cost of your model but if it is not over 10,000 btu's or so just let it run until it dies and replace it. At some point the motor will most likely overheat and blow a fuse or trip your circuit breaker. I own 2 Frigidaire window units myself.
Aug 14, 2012 | Heating & Cooling
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Keeps flashing ES, not cooling. Not even one year old.
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's as hot as it's been this year. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Aug 14, 2011 | Frigidaire FAC106P1 Thru-Wall/Window Air...
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
I have an old (25 yrs or so) through the wall Whirlpool ac. I plugged it in and it runs and cools but it is noisy. Sounds like the fan is hitting or something. When I switched from Hi cool to Low cool...
A through the wall AC unit that has lasted 25 years or so? That's amazing and unheard of !!!
iI it's tripping a circuit breaker, there's an electrical problem with one of the circuits, within the unit and that can be dangerous. Certainly repairing it is an option. But, at 25 years old, I doubt that there are many parts for that model left in existence. Not to mention that the cost of troubleshooting it, parts and labor may cost almost as much or more, as a new Energy Efficient unit would cost.
You have to admit, you got your monies worth out of it over the past 25 years. So, if it were me making the decision, I'd opt for a new Energy Efficient model, with the same cooling capacity as your old one.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Whirlpool ACC108PS Air Conditioner
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
CARRIER WINDOW AC IN INDIA
clean the drain system, find the restriction
Apr 21, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Fidgerdare electrtolux air conditioner
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAH106R1T Thru-Wall/Window Air Conditioner Logo
22 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
