Question about Dometic Rooftop RV Air Conditioner
Air conditioner stopped working, nothing works, breaker is on, power to air conditioner is good, It was working just fine and then every thing stopped. All the other electrical things are working just fine.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Compressor stopped working. Air handler works okay. Checked wiring in thermostat-that is fine. Air handler is not frozen up. Breaker shows fine on meter.
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 14, 2011 | Carrier Air Tools & Compressors
I have a Rudd natural gas heater and central air system. The Air has been working fine all summer and now nothing works ,AC,heat and even the fan does not work. I tried changing the thermostat with no...
check for power at unit, as it may be the disconnect fuse/breaker. The only other thing is the main board, but it sounds like there is no power to the unit. I hope this helps Tim
Sep 23, 2010 | Ruud Heating & Cooling
My air conditioner was working fine until it just stopped working. Thermostat shows no readings whatsoever. The unit outside dose nothing as well. We have changed the filters, reset the breaker switches...
Sounds like the transformer burnt out..or the t-stat went bad...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 20, 2010 | Heating & Cooling
Stop working not doing nothing
Check the cord. Reset it. Check the circuit breaker. Is the filter clean?
If all of that is good you could have a bad capacitor. If it looks swollen or leaky that is the problem. A bad capacitor could cause the fan and compressor not to run IF the power is there. More Here
Jul 06, 2010 | Kenmore 73089 Air Conditioner
Amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Jul 11, 2009 | Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM...
Central air unit problem
Check inside that breaker box for fuses.
Sep 06, 2008 | Amana Heating & Cooling
Rheem Central Air united stopped working, no hum but power is there
It looks as if the 24 signal from the thermostat is not getting to the contactor. Or possibly the coil in the contactor itself is dead. Or a third option may be a bad control power board in the condensing unit itself. If you feel comfortable reading through these devices comment back. PLEASE REMEMBER THERE IS HIGH VOLTAGE INSIDE THE CONDENSER AND A CAPACITOR.
Jul 06, 2008 | Ruud Heating & Cooling
Air will not come on
hmmm..sounds like an amperage issue..what's the rating on those units. other thing..is plugging in at your place, is most likely hitting an invertor, which needs enough juice on back end to power those..check with the previous owner to determine what they did
May 31, 2008 | Dometic Rooftop RV Air Conditioner
My air conditioner stopped working.
lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Aug 11, 2006 | Kenmore 6000 BTU Single Room Air...
Dometic Rooftop RV Air Conditioner Logo
220 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
