Printer provides false "load paper"
  • facarey May 27, 2011
    A Canon MX340
    Paper just doesn't grab.
    Can't get in there to clean roller.
    Perhaps is sensor. Just 6 months old
    suppose Best Buy may handle
    under warranty.
    yes. Not a complicated problem... but a pain when not
    easily fixed.
    Genius:
  • 1,098 Answers
Hi there.
It is possible that there is something wrong with the sensor not reading right. Can you tell me the printer model?
Thank you!
Posted on May 26, 2011
  • 1 more comment
  • Ivy  Cada
    Ivy Cada May 27, 2011
    Blow air all through it, push card stock through paper paths where paper or dusts cookie dusts might have settled on the paper sensor.
  • Ivy  Cada
    If still wont work, since you are still under warranty, take it to the store and take advantage of your warranty.
    Thank you!
  • Ivy  Cada
    Thank you!
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
We have a 4250. When printing from our software we get a message that reads "manually feed tray 1" or "click the check mark to print from tray 2". No matter what settings i change i...
This is often caused by software asking for paper that is not loaded in the printer. You can use the paper path test function in the diagnostics menu to ensure that tray 2 is working properly. Also check your driver settings to make sure that the paper size shown in the driver matches what is actually loaded. You need to also check and make sure that the paper type for tray 2 is set for plain paper, otherwise the printer will only print to that tray if you ask for the paper type that is set.
Jul 12, 2011 | HP LaserJet 4250n Printer
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
WHILE TRYING TO PRINT FROM THE NETWORK, WE GET AN ERROR MESSAGE THAT READS: "LOAD B4 JIS(257X364)" WHAT DOES THIS MEAN?
Hi!
It seems the printer is looking for B4 size paper!Cancel the print job and make sure that the page you want to print is set to A4 or LTR depending on what size paper you use!!
Hope it helps!!
Jan 13, 2011 | Office Equipment & Supplies
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
