Question about Dehumidifiers
I have a danby ddr7009ree humidifier which I am trying to drain with the hose in the back however water just keeps filling in the front bucket. I have removed the rubber plug from the back of the unit.
    Brigadier General:
  • 4,736 Answers
The continuous drain hole (where the hose is inserted) is clogged. To remove the clog, you will need an 18" long plastic Zip Tie (or something similar. But NO wire cost hangers) that will fit into the hole.
Insert it slowly and push until you reach a bend in the tubing. You will need to gingerly work it past this bend until the Zip Tie bottoms out or you run out of Zip Tie. Then, while rotating it, pull it out slowly. As you reach the end of the Zip Tie, be prepared for some water to follow. Also make sure that the drain hose, when reinserted is not crimped and the end is lower than the drain hose connection. The unit does not have a pump. It relies on gravity to drain water through the hose.
Hope this helped you to solve the problem. Please let me know. Thanks.
Posted on May 26, 2011
Trouble with disposing of water. I have it hitched up with hose, but humidifier insists on filling the interior bucket. Help please
For the hose to work the unit must be elevated somehow so that the bucket will not fill. Or somehow the unit must be higher than the end of the hose. If you put the hose down an open floor drain that should suffice.
Jul 12, 2015 | Soleus Dehumidifiers
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
How do I switch from continuous drain to draining into the bucket? I have a Danby Pro dehumidifier. Thanks Tyler
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR5009EE Dehumidifier
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
Looking for replacement blower fan for Danby premiere DDR 7009 REE. The part is ABS D5304-130. Any help?
If your Danby humidifier is still under warranty, call 800-263-2629. If it's not still under warranty call
800-496-6049.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | Danby DDR7009REE Dehumidifier
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
142 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
