Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
"power failure check food for doneness GE
  • 4 more comments
  • davidaucoin1 May 26, 2011
    I can't reset screen. I unplugged no change.
    I hit ok. Nothing. The screen doesn't accept touch
    Ge micro. Screen stuck at " power failure check food for doneness. Unplugged no change
    how do I confirm/ Is there something I couldcheck? All I did was open the door befor the food was done. No power surge ..that was it
  • davidaucoin1 May 27, 2011
    thank you...how it happened. Coking soup, got to 30 secs left and opened door. wouldnt reset, unplugged than the msg appeared. If I disconnect the top door switch the fan starts and the light comes on. but still no control of the panel. Message still there. Does that cause for other possible solutions?
    Thanks
    thank you.
    I am technically competent. I am an engineer by trade, a HW engineer, And an electrician. So if you point and guide me I can troubleshoot. Please
    Thanks
    Dave
    ill let you know! thank you
  • GE Master
  • 11,800 Answers
That error message signals the fact that the high tension for the magnetron is missing - an actual part inside the power source has failed. Hardware failure, so reseting would be useless.
Since the tension in that section of the power source is beyond 5000 volts you can't repair it yourself : not only you will need special components that are not available to an average customer but you will need special high voltage testing equipment to identify the failed part - only a pro repair shop will have them, you must take the oven to one of them.
And in the mean time keep the oven unplugged from the mains, otherwise the safety system might also fail with dire consequences.
Posted on May 26, 2011
  • 1 more comment
  • Azrael SRL May 27, 2011
    When you have opened the door the safety system has kicked in and it has cut the power to the magnetron - most likely this has generated a power surge that backfired in the power source and fried it. There is a small chance that the power surge might have fried the safety system's relay so now the power source - even if it's still operational - can't deliver the power to the magnetron. To find out for sure which the oven might be opened and the power source tested. But, as i said, this can be done only by a repair shop.
    The power source is a simple analogue one: transformer, capacitor, rectifying diode. Here you can find a generic manual on how to test the microwave system http://www.repairfaq.org/sam/micfaq.htm
    Please remember, there is extremely high voltage there, you will need special tools for testing and to properly discharge it before working on it.
    OK.
    Top Expert:
  • GE Master
  • 75,797 Answers
Hello
The message means that after you set the timer and pressed start to cook food the house power was interrupted and the ovens safety circuit detected the power loose and warned you that the food may not be cooked due to the power interruption.
  • yadayada
    yadayada May 26, 2011
    It is very likely a power surge has burned out the central control circuit board, in most cases this cost more than price of a new oven to repair.I suggest you replace it.
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
I have a GE Profile XL1400 over-the range microwave which is about 12 years old. Suddenly yesterday morning the microwave would not cook the food. It turns on and runs just as it normally would, but the...
At the ripe old age of 12, the magnetron tube which makes the microwaves has most likely failed. A sudden no-heat condition is one of the most common ways they go. It's possible to replace the magnetron, but it would be an expensive repair. The tube is the most costly part, and this repair is one that should be left to a professional because of safety concerns. Between the part cost and labor, it usually more economical to replace the oven with a new one.
It is possible that something else is causing the problem, such as a failure of the control circuit board or the high-voltage power transformer. It's still not worth the repair since the 12-year old magnetron would be a failure waiting to happen. Take this opportunity to start fresh.
Nov 28, 2010 | GE Microwave Ovens
Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave power interruption
the unit may be detecting a mal-functioning magnetron.
Jun 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
103 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
