Question about Casio ClassPad 300 Calculator
Hi, My casio classpad 330, touch pad is not working , could you please help to get working. Thanks Garry
SOURCE: casio classpad 300 plus
install FA-CP1 from disk
COnnect the calc
go to handheld assitant
click install add-ins
choose the game
*games an be found at planet casio, always end in .cpa*
Posted on Feb 08, 2009
  • 8073 Answers
SOURCE: Incorrect answer when expanding on casio classpad 330
I don't quite understand what you mean by expand a problem. The expand( command is used to develop expressions such as (ax+b)^2.
For this expression the calculator will give a^2.x^2+2.a.b.x+b^2, which is the correct answer. The dots stand for the multiplication sign.
If you tell us what you are trying to do, we might be able to advise you better.
Hope it helps.
Posted on Oct 10, 2009
  • 8073 Answers
SOURCE: Replace Casio Classpad Touch Screen Protector
Th ClassPad has a touch screen and a plastic cover to protect the touch screen. If we are talking about the plastic cover you can sure remove it by sticking one end of a piece of non smudging tape near the corner and pulling up gently on the other end. Do not throw it away.
Actually, many people do remove the protective plastic claiming rightly or wrongly that screen reflection is diminished. It is up to you.
Hope it helps.
  • 8073 Answers
SOURCE: how to use NumSolve on the Casio Classpad 330
Sorry the solution was posted as a clarification request. Here it is at the right place.
  1. Turn calculator ON.
  2. Look for the NumSolve icon.
  3. Tap the icon.
  4. The equation editor screen opens with the word Equation: on one line and a small rectangle on the next one.
  5. At the position of the rectangle, type in the equation.
  6. Do not forget the right hand side.
  7. Press [EXE].
All the non-numerical variables, parameters are then listed with a radio button next to each one of them.
  • Tap the radio button next to a variable and enter a value for a parameter.
  • Repeat for all known values.
  • Last, enter a guess for the unknown you are solving for and
  • set the bounds between which you suspect the solution to be.
  • While the radio button for the unknown is still checked, tap the Solve Menu at the top of the screen,
  • select Execute submenu and
  • press [EXE].
  • Alternatively you can tap the Solve at the left of the toolbar.(see picture).
If all goes well and the solution is found (this dependent of how good your guess is), the calculator returns with the value of the unknown and displays the difference
Left side-Right side = 0 or a very small number.
If the solution cannot be found you will be prompted to change the initial value (your guess) and/or the bounds. Hope it helps.
Posted on Dec 08, 2009
  • 47 Answers
SOURCE: how to do binary,hex BCD and decimal on casio
to convert between bases, go to keyboard, then cat(alog) and press B to scroll down to baseConvert(
syntax: baseConvert(value to change, original base, new base)
e.g. to convert 1100 from binary to decimal
baseConvert(1100,2,10)
Posted on Feb 18, 2010
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Grabar un numero en memoria class pad 330
5a08c0ca-fb31-4344-a1ce-1b030b9c7f95.png da351a27-4004-41b0-bafd-6714b1ccc193.png
Choose a variable name and assign a value to it.
Mar 02, 2014 | Casio ClassPad 300 Calculator
Need service manual for Casio PhoneMate TI330
do you mean the Casio ClassPad 330? since the Phonemate is a telephone not a calculator
http://spot.pcc.edu/math/download/calculator/ClassPad330_manual.pdf
please vote for me if helped :)
Jan 18, 2012 | Office Equipment & Supplies
How do I enter degrees minutes seconds on casio classpad 330
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
May 12, 2011 | Casio ClassPad 300 Calculator
Can you update a classpad 300 to a 330 operating system
It depends. If the ClassPad has OS 1.x you can upgrade it to 2.x freely. However you need to buy (separately) the ClassPad manager 3.x to be able to upgrade the OS to version 3.x. After that further upgrades appear to be free.
Feb 05, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
Hi, I have a Casio Classpad 330 and I have problem with my touch screen. There is nothing happened when i tapping on the screen, but the keyboard is working properly. It seems it is damaged or corrupted....
I can give you the following suggestion.
The touchscreen will recognize your
stylus tapping if you simultaneously
have any of the keyboard buttons pressed (except 'Clear').
Once you see the whole menu (after screen
calibration and brightness settings) press
Clear than Exe than Clear and the screen
should be touch sensitive again.
Hope this helps.
Sep 08, 2010 | Casio ClassPad 300 Calculator
How do i enter degrees minutes seconds on classpad 330?
Sep 06, 2010 | Casio ClassPad 300 Calculator
How do you install games onto the casio class pad 300 plus?
you need the installing cd that comes with the package install the add-in application thingy.... connect your classpad to the computer run the add-in application on the computer... hope this helps all =D
Jan 15, 2008 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
762 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
