Question about Panasonic KX-T7433B Corded Phone
My KXT7433. I have assigned a ext number to one of oue in coming lines, so when it rings i acnnot pick that line up. How do i earse this ext number
  • Panasonic Master
  • 2,460 Answers
From the idle phone press PROGRAM 99 and the button you messed up. Line numbers are programmed with a 0 in front of it, so if it was line 5 you dial 005 and STORE. Back to a line button :-)
Carl
Posted on May 26, 2011
Testimonial: "Fantastic, thanks a lot. It worked"
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
I want to disable a call from going to voicemail
Changing programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
enter in "#206"
the display should say group call distrib and Group:
enter 7.
the dislay will then say group call distrib 7 line:
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say group call distrib 7 L01 and 1 assigned
enter 2 on the dialpad (not assigned)
enter feature "00" when finished
hope that helps
Feb 12, 2009 | AT&T Lucent MLS-12D Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Feb 03, 2009 | AT&T Lucent MLS-12D Phone
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Panasonic KX-T7433B Corded Phone Logo
147 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
