Question about Philips Magnavox 51MP392H Rear Projection Television
What does SDM code means in the right hand corner on the tv
HOW TO RECTIFY SDM ERROR 10
The set is Philips; I assume. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 22, 2014 | Televison & Video
What does the small rotating circle on the top right hand corner of my sony bravia mean?
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2014 | Sony BRAVIA KDL50EX645 50 Inch 1080p...
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
What does error codes: B0100 and B0140 indicate wrong on a 2011 Buick LaCrosse CXL 3.6 V6 eng.?
B0100:
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0100, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0100 is present then the front end sensor1 has to be changed.
B0104
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0104, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0104 is present then the front end sensor2/right has to be changed.
i could not find anything on the B0140 code so i included the B0104 incase of typo
May 18, 2014 | 2011 Buick LaCrosse CXL
Tv switches off by itself
the tv may be overheating
try putting a small fan blowing air directly behind it.
if this doesnt help then you may need to take it to a repair shop.
Apr 26, 2009 | Televison & Video
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
Help
You must like to do things the hard way..
But since you want to do it, then this will be your path.
You will need..
  1. A 110v/240v power supply. This will mean you need to install an inverter from your cars power to take it up to the higher rating. The 110 or 240 will depend on the country you are in of course.
  2. A video tuner box, You will find these at your local PC shop. You will also be able to connect things like Xbox or PS2/3 etc to that box as well.
In a nutshell, by the time you hand over the money for the inverter and the TV box, your in for some $$$ and alot of work to just hide all the cables.
Apr 21, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Wharfdale 21
From searching the net pressing the "pp" button 3 times will open a hidden menu.
Apr 15, 2008 | Wharfedale Moviestar 60+ System
Philips Magnavox 51MP392H Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
