Question about Whirlpool Duet GHW9150P Front Load Washer
My washer wont agitate or spin - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • Whirlpool Master
  • 2,651 Answers
Kind of a vague description, but likley cause is a bad or clogged drain pump, not allowin water out to spin, removing bottom cover will gain oyou acess to "button trap" portion of pump housing..
uunscrewing "button trap" willallow you to clean oout debris, but be warned that any wate in tub however little or lot there isin machine will also be coming out as well.i genreally grab a black plastic garbage bag and surround the opening prior to unscrewing the trap cover to catch the deluge of immenent water!!!!
usually determine this as well, if by turning off water supply, then select the "drain spin" cycle. Start the machineand in a bout10 secs or so youll usually hear teh pupmp activate, but instead of mvoving/drain water it simply sits ther HUMMING..
Posted on May 26, 2011
Wont agitate or spin everything else working
hi Paulmahoney.
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
read up some more at this link might help you out some more.
Washer Doesnt Agitate or Spin
or this link.
washing machine Wont agitate or spin Google Search
Dec 14, 2017 | Washing Machines
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Washer wont spin....it agitates and drains but wont spin when it gets to the spin cycle. timer still moves.
Tough to say without doing some testing. First thing to check is the coupling. It may sound like its agitating and may not at all. IF it really does agitate and won't spin, I would start diagnostically testing the timer. That isn't something your average homeowner can do though.
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Wont spin
just the agitator wont spin? take the top off it, then you pull the cap off. there should be a bolt down there to take off. then pull the middle half off and replace th 4 agitator dogs.
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
